Mostly throwing this out for discussion and to clarify a few things that nag me about lashings. I'm looking for observations / suggestions from the brain trust here on best methods for high load lashings. In the back of my mind the attachment point starting the lashing (eye splice) seems like it may be the weakest link. I'm also interested in which finishing method people prefer for high load lashings.
Those nice Colligo terminators have individual passes for each run of the lashing line. With that setup I would assume each leg of lashing will become similarly loaded. If my math is right each lashing loop gives approx 1X load rating of the lashing. 4 loops is then 4X rated load. So if the 4 passes share the load = 1/4 load per loop. For this example, does the eye splice really only see 1/4 the load? It always nags me that the eye splice is approx 1X rated for the lashing but we multiply the load rating because of the extra loops. I'm sure someone has done destructive testing - is there a resource with results somewhere? Same idea for load rating as the multi pass covered dyneema loops I suppose.
When you lash between two eyes the tensioned lashings are forced into a bind. I would assume the binding creates some imbalance between individual passes which will have an effect on rated load and the load seen by the eye splice. Any comments on this?
For finishing the lashing there seems to be two trains of thought; create an hourglass (Colligo) or two parallel paths. They both are proven to work. Anyone have input on what they have seen to be the best?
I like the half hitch method shown in this video (about 10:00 in) with two parallel paths. Not sure I like the use of a cow-hitch/larks foot (maybe that was just for the sake of the video).
https://youtu.be/BqrJ2d4aXWE
Thanks in advance for the input.
