alanfw
I've successfully wired in my new Lithium battery as house battery, keeping the remaining good lead battery as a dedicated start battery. Still trying to get my head around charging process to maximise life of the battery.
My boat has a Statpower Truecharge 20 (isolated) with two positive outputs. Up until now, I left the boat plugged in to shore power to keep the batteries charged and to run the fridge. There is also solar (supposedly 200W, but I'm lucky to get 120W). I now have the Statpower Truecharge connected only to the start battery, but I'm worried that the solar might not supply enough current to stop the lithium battery going flat (and I'm also thinking daily discharge/charge will reduce the lifetime of the lithium battery).
I'm now thinking I could use the second Statpower outlet to keep the lithium battery charged and run the fridge without drawing on the battery - it has several settings that appear similar to recommended settings for conservative charging of the lithium battery. (Specifically I was thinking of the 14/13.1 bulk/float settings - see attached photo).
Any thoughts?
As an afterthought, I have the two batteries isolated from each other - the house circuits do not appear to be earthed to the engine. To charge both batteries I would need to have a common negative. Are there any pros or cons in keeping the two batteries isolated?
Any thoughts?
