This seemed most appropriate forum for the question. I'm not doing any single handed ocean racing or anything. Just trying to sail my local waters. having a good time but I am having inconsistent success with a major part of sailing my boat: getting the sail up without much issue.
Its a marconi rigged catboat. I believe 130 sq ft of sail area. I am sailing with my wife, and also want to go out alone.
Most of the time in light breeze I can get the sail up with minimal fuss. Point into the wind best I can, raise topping lift a bit and hoist the sail. I usually have the engine in neutral and centerboard up. Once sail is up I drop the board, kill the engine and off we go.
If the winds are a little gusty or variable it all goes to hell. The boat tends to go beam to the wind while I'm trying to raise the sail. I keep the sheet free. Trying to have my wife at the tiller is not really going to do anything with no headway, but I have tried having her center the tiller, and even just let everything go. Also have tried to get her to hold us into the wind with tiller and engine in gear and making way, while I am up on the bow, and we wind up off the wind and struggling anyhow. We either get the sail up and continue on our way eventually, or regroup. But sometimes its far from seaman like and I must be missing something.
What I get:
sheet loose
some topping lift
point into wind
hoist sail and fall off once everything its set (outhaul, halyard, downhaul etc.)
I would like to be able to do this without the engine if at all possible. is it better to have centerboard up or down? Is it better to do with the boat moving?
I have also considered a shock cord from bottom of boom to tiller in such a way that if I do go beam to wind the boat should theoretically go into irons should the sail catch wind while Im hoisting. Any advice appreciated.
What I get:
sheet loose
some topping lift
point into wind
