Raymarine SmartPilot terminal strip connectors
waXrules
Looking for any information stored out there in the collective.  Friend just received a pre-owned Raymarine SmartPilotX-10 and it is missing some pieces.  Most of the pluggable connectors for the incoming wires are missing.  Does anyone know if these parts are available anywhere or who made these connectors? Thanks.
Alex W
330
Seattle, WA
Those are made by Phoenix Connectors.  You can find the part number on the two that you have you can order more of them from Digikey, Mouser, or probably even Amazon.  They are very common.
Zonker
7,468
Canada
I'll just add they are very easy to pull the tiny wires out of these connectors. I had my computer in a wet locker and it happened more than once. Protect the wiring.
Alex W
330
Seattle, WA
That is a good point.  Those T-shaped cuts at the edge of the board are there so that you can ziptie your wires to the board and prevent them from pulling out of those connectors.
There are few pictures of people actually using them as intended, but I finally found one:
