Wind speeds measured where and at what elevation? These are pretty tall rigs and depending on the stability at that time, the winds at the surface could be considerably less than what the rig is experiencing.
Most likely 6 kts with a hand held device in a RIB.Wind speeds measured where and at what elevation? These are pretty tall rigs and depending on the stability at that time, the winds at the surface could be considerably less than what the rig is experiencing.
No it was a local Opti, they just used a picture of USA 17 because they thought it looked cool.Is it Oracle being reported to go this fast?
:lol:No it was a local Opti, they just used a picture of USA 17 because they thought it looked cool.Is it Oracle being reported to go this fast?
Needs a couple of plastic goldfish hanging inside!Most likely 6 kts with a hand held device in a RIB.Wind speeds measured where and at what elevation? These are pretty tall rigs and depending on the stability at that time, the winds at the surface could be considerably less than what the rig is experiencing.
Cool pix. I dig the transparent wing panels.
Or some troll flies?Needs a couple of plastic goldfish hanging inside!
James doesn't get need to get angry to tack USA 17.Note that the article says "just a few seconds to tack" ("Et un virement de bord ne dure que quelques secondes.")
I assume, since "les huit équipiers donnent l'impression de ne pas faire grand-chose." ("The eight sailors gave the impression that this was no big deal") that USA 17 still has not "tacked in anger".
How about a clownfish and a regal tang?Needs a couple of plastic goldfish hanging inside!Cool pix. I dig the transparent wing panels.
That second line translates better as "The eight crewmembers gave the impression that they weren't working hard." Aren't motors great?!James doesn't get need to get angry to tack USA 17.Note that the article says "just a few seconds to tack" ("Et un virement de bord ne dure que quelques secondes.")
