Recommended GoPro Set Up?
Monkey
3,025
Be very careful with the off brand options. They're cheap, but very hit and miss as far as quality goes. Regardless of the mount, use a tether. The handlebar mounts for bikes work well on lifeline stanchions.
Monkey
3,025
We use the slightly curved mount on the boom.
Thanks for the heads up on the stanchions mount monkey. gonna go find that.
Avoid the one that has a rubber ratchet strap. If you sneeze on it, it'll break. Otherwise I've had pretty good luck with the random choices on Amazon. Can't stress enough... Use a tether!
Varan
2,175
Don't do it. You do not need to record every moment of your life. Nobody cares and the not so green server farms sucking the life out of the mighty Columbia are already filled with useless bits that nobdy cares about. Two years from now you will have days of useless video saved somewhere that you don't even remember. Develop your memory instead and cherish those moments. </rant>
Monkey
3,025
My favorite mount! Worked great to see what critters were living under the deck, and fun to torment my dog!
ProaSailor
dreaming my life away...
6,199
841
Oregon
I use Horizon True. Excellent for on the water videography with a Go Pro. I use a Mast Mount as well as a Backstay Mount.
http://www.horizontrue.com/
Wow! That is very cool. Four different models: http://www.horizontrue.com/self-leveling-camera-mounts.html
