Am curious if the outboard end of this and other foils may get actuated to flatten when unloaded and they surface, to act more like skimmers.I think the current TNZ Banana foil is a anhedral foil. It may actually become Gull winged when loaded but we currently cannot see whats happening underwater.
I think also the built in seamless flaps are actuated by this flexing to accentuate the benefit?I think the current TNZ Banana foil is a anhedral foil. It may actually become Gull winged when loaded but we currently cannot see whats happening underwater.
By exactly the same metric LR have just as much chance of being in the same doom spiral as INEOS if their boat is slower, you couch the LR proposition as interesting, whereas is INEOS- doomed to failNo bias, just facts. I spent my whole career doing research and product development.
It is much more accurate to measure the impact of changes if you do them one at a time instead of all in a handful. Having two ”identical“ AC40’s on autopilot is an ideal situation to minimize the noise and give the best comparison between changes. Having one boat that is significantly slower and with a completely different design adds several variable that have to be estimated out in order to measure any changes. This adds a lot of noise to the process and makes it very difficult to actually measure slight improvement.
There are already so many variables like sea state, wind variations and boat handling that make it very difficult to measure absolute changes. No need to throw in a test platform that can’t keep on the foil over 50% of the time in maneuvers. They will be able to measure large improvements using the T6 vs AC40, but the smaller incremental changes will be difficult.
Alinghi, bearing off first in R1 of AC33. You can hear Rennmaus saying 'Classic Start!'
You can see what happened when CZ was able to bear away much sooner than DZ.
On the water, pre-start, Race 1, America's Cup 33, Feb 12 2010, Valencia
I have not made any such comparison of LR vs INEOS. LR will also have many of the same variables problems as INEOS, but LR LEQ12 is much faster and they have shown much better control of their test boat. I am not all doom and gloom on INEOS, it is just they have made some choices that make it a much tougher challenge.By exactly the same metric LR have just as much chance of being in the same doom spiral as INEOS if their boat is slower, you couch the LR proposition as interesting, whereas is INEOS- doomed to fail
I think it is perfectly possible for the Banana foil to have a twisting trailing edge as apposed to a normal flap. If the outboard end is fixed and the inboard end moves you can achieve the desired twist for the flap effect. They have been talking about it been harder to control and than their normal foil and this is probably due to different response rates etc.I think also the built in seamless flaps are actuated by this flexing to accentuate the benefit?
As to Ineos they are still building their data base, they have chosen simple straight forward foil design as their base design. They would have picked the span and cord to best suit the conditions where they were going to test it. Once they know they have a sound base to build on they can start playing around. TNZ and LR are miles further down the development curve, but once they can start computer modelling in earnest Ineos's can easily catch up on the design side they may struggle for time on the water.
I meant to point out that whilst this may seem minor, with the AWS these boats get it's more significant than most people are used to. I know from sailing with much smaller sails in higher TWS that it's quite a lot of force.Perhaps it's the exact opposite of wanting to back the sail.
An auto-tacking jib is pushed across by the jib backing, very slightly, but a bit. That slows the boat down a bit.
If they move it by hydraulics then if at exactly the right time and rate it would not slow the boat (as much).
Easy to get right with auto-control, but very hard to do manually. But possible by following the right instruments. It's even possible that the main traveller is set for the same.
I'm not asserting it, but it's another possibility that they might be testing. They will be going for small gains this time
Agreeit would seem like a bigger potential gain than a pre-start duel
Not sure. I get what you're saying, but also I've seen a couple clips where it appears to come over later in tacks. Although Bleddynn also said they've had a few teething issues with it in his last interview.I meant to point out that whilst this may seem minor, with the AWS these boats get it's more significant than most people are used to. I know from sailing with much smaller sails in higher TWS that it's quite a lot of force.
Furthermore it occurred to me that it's not just drag, but also turning the boat with so much force that it might make it harder to stop the turn, hence more rudder angle.
Anyone have any views? @Mozzy Sails ?
I must admit it's an idea I have blown hot and cold on overnight, but it would seem like a bigger potential gain than a pre-start duel
Me too, the very obvious one from the R1 start of AC33 that I posted (there are better vids of all that whole thing...) where the boat that peeled out of the dialup first gained an absolutely huge advantage. The Alinghi cat may or may not have used some windward jib sheeting to accomplish that, but it's certainly possible.I just used the pre-start as a quick lazy example I could think of at the time.
^ from a link there.. dialups can matter!Some forum posts about that start
Did Dogzilla ever practice starts??
Got into a bit of a bar discussion about the DZ/CZ starts and have a clear memory that Jimmy Spihill once said that BMWO had never actually practiced a match race start or even sailed an AC race course before the gun for Race 1 in Valencia. I"ve found an interview where he says they had never...forums.sailinganarchy.com
