allweather
After gaining some much needed experience last year and busy with other projects over the winter I now want to redo my diy electric outboard construction. This time in carbon to save some weight and get it stronger at the same time, but mostly to get some adjustments in(needs to be 20mm smaller to pass the backstay adjuster effortlessly) and insert some proper slide bearings.
To that end I want to replace the 30mm/M30 stainless shaft that comes originally with a 19/12mm Carbon shaft(don't want it thicker than that) and would like to hear if anyone has advice how to best get an M30 thread on that shaft.
Ideally I'd love to get it in G10, but don't even know where to find something like that in Europe, so my next step would have been to have a stainless piece machined that I then can glue onto the carbon shaft. Which isn't great, but okay.
Ideas?
Picture is how it is right now, I want to have the next version to be slimmer and smaller overall so that the round/turning part can use 60mm slide bearings that I have found relatively cheaply and readily available.
Ideas?
