Marcjsmith
- Thread starter
- #421
Well in the vein of. “That sucks”. I reinstalled the water pump with a new impeller, fired up the engine, and then promptly added af to the raw water side to winterize.... only to find out the water pump leaking. Upon closer inspection I can see a rubber seal on the shaft that not in the right position.
On the plus side, I was getting some water in the engine bay and I was concerned that I was getting a bad seal on my pass dripless shaft seal. Maybe the water pump has been leaking and I was attributing the leak to the pss and not the water pump.
Hopefully the pump is rebuildable.
