MauiPunter
Will sail for food
I found various diagrams online in regards to rigging jacklines, checked out the market for the equipment and the accompanying text and something isnt adding up. I have read that the jackline and tether should be setup such that you dont end up in the water and the tether should end at the edge of the boat. However, it seems like every tether on the market is 6' long. Since you rig up jacklines on each side of the coach roof generally, unless you have 6' wide side decks (not including the stretch of the tethers and jacklines) you are going to end up in the water. Perhaps this is not a problem as long as you are not at the back of the boat where you want the stern end of the jackline to be a tethers length from the stern, where you dont want to end up being dragged behind the boat. What is the reality of these systems? What have you found to be the best practices?
