estarzinger
- 1,098
^^ except, unfortunately, where spinlock has chosen to place it on the vest makes it extremely difficult to access when the bladder is inflated. There have been a couple incidents where a sailor found it impossible (fortunately no-one has died from that yet . . . . but we do of course have the UU incident where the spinlock bladders failed).
The reason the spinlock was designed as it is (with a cowhitched tether to a webbing loop and a hidden knife) is because pro racing sailors using grinders wanted as little metal as possible on the other guys chest - they would hit their knuckles on the kong/gibb type clips.
If you use "two-up" grinders on your boat that might be a consideration, but most of us do not.
"Most" authorities would suggest both a 'release under load' shackle on the harness end of the tether and a knife is the safety best practice.
Regarding the spinlock knife itself . . . .
It is not clear to me if the spinlock knife is generally useful on deck or really only specific to cutting webbing. I am guessing that it would be considered specific to cutting webbing and you might want to carry a more general purpose knife also. But I would be interested in hearing from a knife 'expert' on this? Will it quickly cut a 12mm vectran halyard or is a 'regular' blade better for that.
And . . . does the spinlock hook actually meet the various knife requirements and recommendations (just for instance ISAF requirement 5.05 A knife, one shall be supplied to each crew member to be worn on the person at all times) or do you need another 'general purpose knife' to meet these requirements? I suspect most crew have (would be required to have) an additional general purpose knife, simply because they do not wear their vests all the time, and the kinfe is required 'at all times', but I have not seen this come up in an inspection yet.
