harryproa
- 172
Munt,
I appreciate your niceness and I'm glad you like the boats, but you are wrong.
An unblurred (not sure why it deteriorated, if anyone has a clear version, I'd like to see it) copy of this video was posted 15 years ago and many times since. It shows an unstayed masted Harryproa in more breeze than any of the Sidecar videos I've seen.
I am not saying it proves anything beyond the boat's ability to sail at windspeed under main and jib in 10 and 15 knots (5:15) of breeze, the ability of an unstayed mast to flex in a gust and the lack of deck gear a self vanging rig requires, just that it has not attracted any discussion on multihull unstayed rigs (or the advantages of Harryproas, but let's not go there), but plenty of personal attacks.
Around the same time, a grossly overloaded 12m/40' Harryproa with unstayed mast was sailed across the Tasman by a novice crew. They broke a ring frame and weathered 45 knots. Again, no boat or rig discussion.
Over a period of several years Rick Willoughby (Australian version of Tom Speer) thoroughly analysed, tested, video'ed and published results of an unstayed rigged 18m/60' proa including wind, boat speed and tracks, tacking angles and leeway, a more comprehensive analysis than for any other proa that I know of.
I've been sailing, racing and busting Harryproas for 25 years so that I was confident about what I was selling plans for. There are a couple of SA'ers who used to collect pics of my failures. Maybe they will post them.
There is also this video of TP going gang busters from 22 years ago. Several threads, but no discussion of the rig, or how easy it would be to depower. Someone with no apparent knowledge of boats or rigs always posts pics of the completely unrelated bow falling off and the thread ends.
The latest posts by Foiled Again, Sailing Tips and Lykke and the Marsaudon video (main and traveller in hand when it's fresh) support earlier ones by your 'extremely experienced sailors' that stayed rigs are the root cause of the reasons multis are being creamed by monos in solo offshore races.
The ability to dump the sheet so the boat drifts, with the rig weathercocked makes reefing a quick and simple exercise. No steering, no winching down the sail, no shrouds to cause pitchpoles and no angle of death where heading up or bearing off are both likely to be catastrophic.
Include a fuse that dumps the sheet when the hull lifts and the "can't/won't/don't sail it hard in a breeze" syndrome disappears.
The 'let's stay in the '80's crowd' simply refuse to discuss this while wondering why the monos are beating the multis offshore. The ostrich mentality towards new ideas of people who think they are at the bleeding edge of non foiling multihull sailing is quite peculiar.
Btw, bearing off works fine in daylight in a little boat, but you need to have been woken at 3 am by a 30 knot rain squall while broad reaching in a multi offshore (cruising or racing) to appreciate that bearing away down the waves and reefing without gybing may (or may not) be the correct move, but it is definitely scary and hard work. Doing it single handed even more so. If that squall builds to 40 and/or there is a lee shore and/or something jams or breaks, it becomes terrifying.
Good seamanship might have you sailing under reduced sail so that this scenario is not a problem, but bumping along at <5 knots every night instead of cruising at >10 because one night in 100 a rain squall might hit makes for boring, slow passages and lost races.
It's so much safer and easier with a self vanging, unstayed rig. And safer again if the sheet is fused.
I would appreciate yours, Foiled Again, Sailing Tips, Lykke, Ryan (especially) and other's views on this (unstayed masts and fuses, not Harryproas), in relation to safe, fast, solo offshore sailing in multis.
