Mambo Kings
Didn't the smiley face give it away?So the sound is not a signal? Splitting hairs Mambo
If you refer to USS Appeal #47, Musical Hum vs RC, the appeals committee confirmed that sounds such as breaking wind do not constitute a sound for purposes of signals given from the signal boat. Confirmed by World Sailing in Case #130.
Ermm. Please refer to my post above where I gave the full and correct definition. We don't know better than World sailing but perhaps we know.....BTW the DEFINITION of Clear Astern states "behind a line abeam etc etc so not a bearing at allbut perhaps you and Steam know better than World Sailing
Rule 4.1 C . Posted above. There is match racing almost every weekend at Oyster Bay. Intimately familiar with the rule.The line I assume you are referring to is the '4 minute line'.
So they "estimate" the line. Surely this fits your meaning of "estimated line" or "imaginary line" that you use interchangeably in your postsMost match racing events either don't use or can't afford the accurate telematics to be exactly 90 degrees, Mark you I could be wrong, I am a relative beginner
Completely correct TJSoCal & @Mambo Kings. It would be absolutely absurd for a "guessed start line" to be valid.
A compass bearing is only relevant when actually setting the mark - where it is is where it is and the only relevant line is the ACTUAL line, not an imaginary line. ... there is no such thing as an imaginary line in the RRS.
Oxford Dictionary. Definition of bearing:.
The rule actually said "line of sight abeam" ,, It is NOT ... a line of sight "bearing"
And not MY definition of an imaginary line, it is those good people at Oxford University Press so perhaps you know better than them too.
"the direction or position of something, or the direction of movement, relative to a fixed point"
Okay, so backing off the phrase "imaginary line" that you used in your post, I think Eye is correct that there are at least 2 examples of estimated lines in the RRSIt is not really a case of an 'imaginary' line at all as the line WAS originally there but without a starting mark marking the outer end it is no better than an 'estimated original' line as it has been altered not only up the course but potentially shortened or lengthened depending on the tack of the boat which hooked it.
Why bother? The discussion has reached the correct conclusionI am going to email my rules mentors - and they are a rare breed who are both International Umpires and International Judges - with the following.
The line the OP had to return to to restart was the start line. The start line was defined in the SIs
The SIs defined the start line between the flag on the signal vessel and the ODM. That applies where ever the ODM moves to.
If your Rules Mentor is any good he will reply that he cannot give you an answer because you haven't supplied him with a copy of the SIs. He/She also cannot give you an answer, only an opinion, because there is no case.
Good Point.See ya on the water - I might be the one with the flag & whistle
SS
I would like to go on record that I agree with absolutely everything you have written
