Mambo Kings
Do what you can to comply with 14 (avoiding contact), and protest if you think another boat has broken a rule.1. At the start, if you are on the layline to the RC, and someone sticks his nose in and you can't dissuade them from doing so, obviously, at a certain point it you don't fall off they are going to T-bone the RC boat. Do you own them room once they have reached this point of inevitability? What about the boat to leeward? ... if he's yelling "up up up" at the same time as the above is happening, what do you do? Just stop and let both go right by?
If windward boat comes in and you havent altered course and Windward boat cannot clear the cttee boat without bearing away and hitting you, then he breaks rule 11. You can luff to dissuade him, until he is overlapped with ctee boat then you cannot sail any higher.
If Leeward boat is calling "up" when you and the windward boat are already inevitably overlapped with cttee boat and cannot luff without hitting cttee boat......then hail "Rule 16" ..."Please cease your luff"
Protest. Easier to win this one with an outside witness. Without one, it's he said, she said.2. Before the start, if a leeward boat is trying to push you up, my understanding is that they can't go beyond head-to-wind. it seemed like some boats got very aggressive in pushing us up, and certainly seemed to have gone past head-to-wind for a couple of seconds in doing so. What do you do if this happens?
A leeward boat can luff right up to HTW with all sails luffing before the start. Because there is no PC before the start.
In the unlikely event that they go beyond HTW and start to fall onto port tack, then they have to keep clear because they are tacking (rule13) and if they go all the way to new chc on port tack, then they have to keep clear port/starboard (rule10).
Most likely they didnt go above HTW, but had flapping sails and continued to luff higher.......then yes, you have to keep clear under rule 11.
Arguably a breach of rule 2. And a downside of tack or cross.3. On the weather beat, you're on starboard and a port-tacker comes along, and hails "tack or cross". You want to keep going left, so you yell "cross". Then the guy tacks right on top of you. Later he said, as it turns out I was crossing cleanly and since you didn't need to dip I had every right to leebow you. I couldn't find a specific rule to address that ... is it just bad sportsmanship?
If you dipped at all, then rule 2 breach. Otherwise he just changed his mind.
A culture of poor rules observance in a fleet can be changed, but it's an uphill battle. You need the respected guys to take a lead, fleet captains to stress rules observance, hold seminars, a spell of lots of people protesting...and so on.4. At the weather mark, you're in a big wall of starboard tack boats headed for the mark when some port tackers come in and tack near the mark. I understand that under Rule 18.2 if they tack within the zone, you aren't supposed to have to head up to avoid them. But this happened all the time. I can't say for sure whether or not it was inside the zone -- there's no dotted line on the water -- but in any case don't they have to completely yield ROW to the boats coming in on starboard? Lots of bumper cars and hot tempers resulted from this, and I have to say I am clueless at what's supposed to happen. For these races, I just pulled the tiller up to make room for them and avoid a crash, but obviously pinching up like this time after time really kills you.
Yes you are meant to head up to avoid them, with two caveats:-
1. If you need to start to head up before they reach chc in order to avoid, then they broke either 13 or 15.
2. You do not need to head up higher than chc. Since in the starboard wall, many boats are eased off as they reach the mark....you need to be sure that you headed higher than a tightly sheeted in chc before you invoke this rule.
