10thTonner
Hazard to Navigation
Umm, ok. What about a Hanse then?Not a baveria sailboat job
2.3 on the richter scale may have measured the Depressurization of the pipe...you are a good reader. but it's also useful to consult your common sense. there were three blasts. at least one of which measured 2.3 on the Richter scale.
further. that a 50 foot party boat - could carry 5 or 6 commandos plus dive gear sufficient to descend to 80m and successfully plant the tons of explosive required. defies belief! I mean, is there even any room left over for beer at that point?
it's all a big joke. and of all the pages in the world discussing it - this one should be the first on board to laugh right along with it.
Got a cite for that?One explosive charge failed to detonate
They have this explosive but will not release the documentation
The explosive charges were 1000 lbs
Industrial size weight
Only a state actor could handle and set in deep water times 4 explosives
yes, the pros know what they are doing.Aith a 50 feet sailboat, they had a payload of several tons plus they are pros who know what they are doing.
I have done working dives to 100m. using scuba.
Very little bottom time, very little visibility, fucking tanks all over you.
I am very skeptical to the point of disbelief that they could also take down and plant 500 kgs of anything in 80 m. using scuba and exiting to a sailboat with no chamber around.
May be there were no scuba divers involved... Or may be the divers just marked the location! 30 years ago, I was on a mine sweeper, we were using tethered diving robots that were already old technology to deal with mines. In 2022 may be there is a miniature version of it, also 500kg of explosive in the water is not that heavy, they could have for instance controlled the descent along a rope...yes, experts know what they are doing.
Just need a commercial fishing vessel. 1000lbs is easy, and also going to have a very good quality sonar.One explosive charge failed to detonate
no you don't.I think that the Bavaria story is believable.
You need well equipped diversJust need a commercial fishing vessel. 1000lbs is easy, and also going to have a very good quality sonar.
Evidently the specialist divers were breathing helium or some special mix for deep workI have only brought things up from depth, so we were diving fairly light to attach lifting gear.
I could not imagine trying to set something bulky down in a precise location 80m down.
Even with the military deco tables that allow for 'acceptable losses' it would still be a very short bottom time and a very long, around 2 hours, deco schedule.
You can skip in water deco, if you have a deco chamber at the surface.
There is no part of this scuba divers on a sailboat story that I can get my head around.
Probably some kinda underwater propulsion device
Still requires significant decompression time that is not practicle without a deco chamber handy and at depth for entry to avoid getting bent when surfacing.Evidently the specialist divers were breathing helium or some special mix for deep work
He was on the crew of the Russian diving vessel?How'd you find that out?
