Quickstep192
I'm preparing to change the gear lube in my SD20 saildrive and the owners manual leaves me wondering if there are two places to change it or just one.
I see references to the upper gear case and the lower gear case. They reference different procedures for in the water or out of the water with references to the upper gear case and the lower gear case, but the lube appears to be ending up in the same place.
So, my big question is:
If I drain the gear lube from the lower unit and then replace it from the dipstick port, am I done, or are there two separate chambers - one for upper and one for lower?
As always, any guidance is appreciated.
