2airishuman
I am planning an upcoming scratch build of a Chameleon dinghy.
One of the questions I am pondering is the best gunwale treatment. It seems to me that nearly all hard dinks built as tenders have some sort of self-fendering gunwale treatment. Among these are:
I am leaning towards trying a variation of #3 by applying a 1/4" piece of solid ultra-high molecular weight polyethylene (UHMWPE) bar. Same molecule as used to make Dynema but in solid bar form rather than little strands. The stuff is slippery, non-marking, tough, easy to keep clean, relatively inexpensive, and does not add much weight or bulk. Epoxy will not adhere to it well so it must be fastened mechanically. I am planning on through-bolting it with 316 stainless flathead machine screws that are countersunk into the UHMWPE bar, going into 316 stainless tee nuts on the inwale.
The obvious disadvantage is that it doesn't provide cushioning. But I'm not sure that the cushioning provided by the other treatments is sufficient to make much difference in the event of a hit serious enough to damage the boat, and the UHMWPE bar provides a degree of additional strength to the gunwale system that the softer products do not.
So my questions are, what you all think of that, and what sort of experiences have you had with other self-fendering materials on tenders.
- Foam covered with fabric; everything from pool noodles covered with firehose, to more special-purpose materials sold already made up by chandleries, to bespoke combinations. These are mechanically fastened, with screws and washers, or monel staples, or with the fabric being folded behind a batten that is then screwed down.
- Elastomeric tubing of various kinds that provides cushioning and a sliding surface in a single material. Includes things like PEX tubing from the home center as well as the fancy EPDM extrusion used on the PT-11.
- Non-marking, low friction treatments that do not provide cushioning. The usual homemade version is polyethylene water pipe cut in half and fastened with screws so that it is mushed down into sort of a U channel shape.
