Self tacking jib sheeting
A
Amati
Mulling over a different self tacking jib setup- track this time- if the jib sheet is run up (and down inside) an aluminum Ballenger mast, does the mast need reinforcement to handle the extra compression?  Thought I’d ask here before I bug Skip again.
I’d like to be able to fly the self tacker (3/4 hoist)along with an upper flying jib at the same time.
slug zitski
774
worldwide
You are adding compression
you could remove compression elsewhere with halyard locks or simply  ask the mast builder if your mast can handle the extra compression
slug zitski
774
worldwide
You might look at the way Wally yachts does their self tacker.
2 to 1 main and Genoa halyards are simple and reduce compression
DDW
972
The weird thing about the setup pictured is it does not reduce compression at all. If fact there is twice the jib sheet load put on the mast in compression. Spreads the load on the track a little is all.
slug zitski
774
worldwide
the two blocks are to spread the high  load onto two  traveler cars… because of the turning angle
it’s still 1 to 1…a continuous loop
the third sheet pulls aft flattens the sail
slug zitski
774
worldwide
Fleetwood said:
If you have the third sheet pulling aft where is the self-tacking advantage?
The third sheet is because that boat is sailing with a maximum size headsail
its not possible to move the track aft
a self tacker  is not a very versatile rig .. difficult to shift gears , sail design is limited
slug zitski
774
worldwide
Wally yachts are esthetic , design driven  , cruisers racers
that boat was designed with a super clean deck .. nothing on deck
this was the design goal
everything is a compromise
you will find that once Wally designs a detail or system ..like anchors that drop through underwater Bombay doors to keep the yachts stem clean  ….other designers follow
PaulK
Instead of adding a third sheet (a twing?) Wouldn't moving the sheet to a lower point on the curved clew board flatten the sail while still allowing it to be self-tending ?  Or is the sail cut with too loose a leech and so needs the sheet pulling down and aft more than it should? The sheets on self-tacking jibs we had on Solings went forward on deck instead of up the mast so there was no mast compression issue. Why is that not being done here?
European Bloke
823
The line would make the pretty deck of the sailing boat look untidy. Try to keep up.
slug zitski
774
worldwide
Not easy to change the clew board position when loaded
an extra sheet its easy to shift gears
On some boats the luff in not full length , you ease the tack down haul and hoist the sail higher to change the sheeting angle when close reaching
PaulK
So...  a third sheet is a Micky-Mouse adaptation by a lazy crew. It could also be used to unload the sheet and enable changing the clew board position. Then stow it away.  While an extra sheet may make it easier to shift gears, it makes it more difficult to tack. It also looks untidy! Shifting the whole sail higher to change the sheeting angle seems like the tail wagging the dog. None of this seems helpful for the OP.
slug zitski
774
worldwide
Explain your method of changing the clew board sheet positions while loaded
Sail luff length is relative to the original poster
European Bloke
823
Your question was about compression in the rig.
I'd be very surprised if a jib sheet load would put enough compression into the mast for it to be a factor. The very lightest cutting edge rig possibly, but it wouldn't be my biggest worry
Make it 2:1 if you're worried.
That said I'm not a rig designer and my advice is worth what you paid for it.
I still think that 99 out of 100 self taking set ups are shit. That wasn't the question either
PaulK
On our Soling we set up a 2" stainless steel pipe that my father had had bent in a curve.  We bolted it to the deck with 3/4" galvanized bolts, held off the deck by chunks of 2x4 in the way of the bolts.  A steel ring with a sheave shackled to it served as the traveler, with a short line led from it to a centerline padeye to regulate the size of the slot.  The sheet went from the clew board to the sheave, up forward to a through-deck sheave, and then to an under-deck tackle whose fall went to a swivel cam at the forward end of the cockpit.  Cheap but effective.  The guys with the Harken ball-bearing travelers all looked very surprised when we beat them.
slug zitski
774
worldwide
At 180 degrees turning , The load on the block handling the self tacker sheet  is 2 x the load on the jib sheet
