jonsailor
you cannot believe the loads that these big alternators cause until you see it running, especially if they are doctored to hit 14.4 Volts.Scott:
Thank you for the details.
You have earned my respect.
We all do understand that you are
"working with what you got" and making the best of it.
The belts on the engine could be reworked in a
manner similar to what they do on some trucks - the double
sheave and two v-belts, or a set of special pulleys and a wider cog belt.
The torque load with all the alternator loads must be pretty bloody high.
Adjusting the alternator field settings down to reduce the alternator torque
loads makes sense, although its a compromise. After all you are throwing
away some of the generating capability in order to save the belts.
as for the vibration? You got an alignment problem,
something out of round or a something out of balance?
thanks,
jerry
It actually stalls the engine if you run both while cold. Some of our single handed yachts, we either have a manual switch or a time delay before they kick in so the engine can get going.
Double belts we found were not a good idea as they wear and stretch different and do not share the load well enough. Maybe a square tooth belt like a Harley drive belt would be the go, I've never tried that.
Most of the vibration is due to not enough rigidity in the steel mounting structure. Being a race yacht, we tend to not go too overboard and there is always a room problem.
Biggest problem is the user of these boats. Both girls live on all the electronics and never put the phone down. None would survive or make it without a sat phone.
I did a 5,200 mile 2 handed race to Osaka on 39 ltrs of fuel. Sure we only used the pilot 21% of the time but there sure is a lot more discipline to be had.
Media chews up a lot and I suppose they all need the sponsors onboard.
