well it looks like at least two of those bolts had washers on them previously... clean up the threads and add some washers and nuts.. i mean that's a cheap fix as opposed to something being ripped out of the deck when you least want it to... and like said before... call the builder..This is the underside of a stanchion base and one of the spinaker sheet blocks on a new boat. Is it normal/expected to not see any kind of nuts on these bolts? I guess there might be something glassed in that these are screwed in to?
I dunno about that, to me that looks like ham fisted installer. Bolt was hanging up partway, hit with hammer. Results in a delamination in the glass around the bolt just like that. Also if there's a backing plate in there and the hole wasn't quite lined up, when tightening it it will do that.well it looks like at least two of those bolts had washers on them previously... clean up the threads and add some washers and nuts.. i mean that's a cheap fix as opposed to something being ripped out of the deck when you least want it to... and like said before... call the builder..
