That is my custom Mark Ellis designed, Betts/Bruckmann built cat yawl.Why don't you all list the types of boats you are showing to the masses?
She's a very special boatThat is my custom Mark Ellis designed, Betts/Bruckmann built cat yawl.
Clever use of the screw-out clear deck plates as port holes. I would be tempted to install them so that the plates screw-out from the inside as it would be just like me to drop one overboard in the current configuration.
No great surprise that it looks like a stretched Nonsuch with a mizzen. The cat yawl was one of N.G. Herreshoff's favorite rigs for singlehanded sailing, which he did a lot. No headsail to complicate things, and a mizzen for maneuvering.That is my custom Mark Ellis designed, Betts/Bruckmann built cat yawl.
In one of his books, Don Street described using the mizzen to back his 40' through a mooring field by alternately swinging the mizzen from side to side.No great surprise that it looks like a stretched Nonsuch with a mizzen. The cat yawl was one of N.G. Herreshoff's favorite rigs for singlehanded sailing, which he did a lot. No headsail to complicate things, and a mizzen for maneuvering.
In pre-engine days, the mizzen was used to hold the boat head to wind for all kinds of maneuvers such as getting underway and anchoring. The year that I sailed my big wooden yawl without an engine, the mizzen was an essential tool for getting the boat on and off our mooring in the middle of a very crowded Newport harbor. Even with that, there was more than a little anxiety at the best of times.
You usually will void your engine warranty if it’s still valid when you over pitch your propSplashed my boat yesterday.
Sadly, PYI was off on the pitch. I am waaaaay under pitch. The motor just rockets to redline almost like being in idle. At my cruising RPM (2400~), I was only able to get 6.8 knots. I was at 7.8 with the three blade. So I'll dive on the prop and bump it up. I am currently at 22°. Per Jerome, every 2° drops the RPM by 250. He is thinking maybe bumping it to 26°.
There is thought about overpitching so you load the motor more and make it work...
I will say the prop is super smooth. I'll report back after I adjust the pitch.
I would imagine that the lid flange would make the above less than optimal for preventing water ingressClever use of the screw-out clear deck plates as port holes. I would be tempted to install them so that the plates screw-out from the inside as it would be just like me to drop one overboard in the current configuration.
My warranty is all done. That being said, I don't like the idea of over-pitching the prop. My father's boat would blow black smoke at full throttle. Not a good look...You usually will void your engine warranty if it’s still valid when you over pitch your prop
We stack our wine bottles in tube socks in a dry, bulkheaded, bilge compartment. Put a few pieces of flexible Dri-Dek in the bottom of the locker to hold the bottles off the bottom. White wine in white tube socks, red wine in gray.Important pre-cruise decanting operations going on.
All liquor must be in square bottles (or be box wine)
Keep the high quality liquor square bottles; when empty, they can be filled with plonk and neither I nor guests will ever know or care.And I’ll be happy not to hear round bottles rolling around in the liquor locker underneath the forward berth!
Good theory but do it with some class.Important pre-cruise decanting operations going on.
