Slot Head Screws
hard aground
106
in quarantine.....
In one of his Tally Ho videos Leo explains the benefits of slotted screws any why he uses them on the build. Don't presently remember right now though. As far as phillips screws go lets not forget about pozi drives
Fenrir1001
32
Let us add another twist. There is a head similar to Phillips used on Japanese motorcycle, the JIS (Japanese Industrial Standard). Whether it is better or worse than Phillips is irrelevant. A Phillips driver works, almost, and most old Japanese motorcycles have JIS fasteners that have been wienered up by a Phillips driver.
OIP.Br0jSN7u4RXYTGlNdfLCYQHaDg
There is also posidrive, similar but not the same to Phillips and JIS but has an extra 4 slightly smaller flanges at 45° to the primary ones
El Borracho
Barkeeper’s Friend
7,280
3,207
Pacific Rim
On any rebuild some of the screws will require their heads to be drilled. Slotted are the worst for this. Plan ahead.
Does anyone else think that while Robertson’s may well be functional they entirely lack aesthetic quality? Like a farmer’s pathetic attempt to improve on the Allen head.
11,889
Slotted screws are great if they are going to be painted or puttied, etc. Very easy to clean the slot. Other drive types not so much.
The other thing, it's very easy to dress a flat tip. Phillips possible but more difficult. Other screw types, forget it. The answer is to go buy a new one.
Yeah, old fashioned as shit. But when I hear people bitch about slotted head screws, I think that their mechanical trades education has not covered some fundamentals.
Captain Ketamine
401
Perth WA
I’ve found this nice screwdriver set, only has one Robertson and Allen key size, but useful handle to allow T bar as well as standard screwdriver handle grip. I’m sure there’s lots of great stuff available in hardware stores in the US.
warbird
1,516
lake michigan
The thing about JIS is that in the 60s and 70s and later, the blossoming Japanese motoorcycles were all fitted with JIS and EVERY backyard mechanic/service guy used Phillips and wienered the fasteners. I have since replaced most with allen head screws on my 70's motorcycle projects.
Vieux Port
Nautæ
200
113
le Port
Roberston "Screwlox"
Sorry "SCRULOX"
The SCRULOX trademark was assigned a Serial Number #72088487 – by the United States Patent and Trademark Office (USPTO). Assigned Trademark Serial Number is a Unique ID to identify the SCRULOX trademark application in the USPTO.
woodtick
It would take all day to count the visible slotted screws on my boat, and every effing one is clocked. They do look way nicer than Robertson. Anything I build I use Robies, but you can't see them, no visible fasteners. Robies go frm #4 to 00, generally.
I think a big, bronze machine screw would look weird in anything but slot head.
Everywhere else they suck.
Nice bike @warbird
Autonomous
Turgid Member
4,646
1,842
The daggerboard case on my new boat was air tight and swole at a high altitude lake, pinching the board. This is the one time a Phillips head screw saved the day. I found a brass Phillips head screw to replace a stainless Robertson fastener on the case, took my smallest drill bit and drilled a vent lengthwise through the brass screw. Viola!
We agree that Robertson screws look rather industrial. FWIW the electrician that did my house clocked the screws on the outlet and light switch plates.
WhoaTed
Antichrist
1,853
944
Holland, MI
Yeah, you need to grind the tips down on a few appropriate-size Phillips bits for those. Works a charm.
WhoaTed
Antichrist
1,853
944
Holland, MI
Clocking screws is one of my OCD traits, I don’t recall where I picked it up about 30 years ago but ever since then I have to clock EVERY freaking screw I tighten or I start chanting about pancakes on Tuesday. The thing about it is that in places where many screws are used most folks don’t notice or realize it’s been done but it adds a finer “finished” look to the work. Yes, all the way down to wall plates.
tane
352
Please check for one of my several 10mm sockets. They're like socks.
metrication is resting heavily on the imperial Americans...
if anything we are having 10mm spanners, wrenches & sockets in profusion over here "in the forest"
10thTonner
Hazard to Navigation
1,843
757
South of Spandau
Oh man! That makes NINE drivers just for “+” heads.
chester
1,820
quare drive and robertson aren't the same are they? don't robertson taper slightly?
