Fleetwood
No problem with the boom shading the dodger and cabin-top panels?
Of course shading does drop input but I have them in series with each other but in parallel with the unshaded targa bar and bimini panels and find they still contribute serious extra charge.No problem with the boom shading the dodger and cabin-top panels?
Why a shame, the 110W have a higher voltage and MTTPs like Victron work better.I bought them last year just before they discontinued the 100s and went to 110s which was a shame.
Looks to me like his boom is center-sheeted. How the hell would sheets get all the way back there?Stunt21 are you worried about a sheet catching your panels during a jibe? I put angle brackets on the outside corners of my panels to prevent a sheet from catching the panels.
I had much the same choice. For me, the weight aloft of rigid panels was just too much.. My flex panels are a good 50 lbs lighter than rigid panels of the same output (and yes, they cost too much).My Tartan 3800 is a fairly average cruising monohull with a fairly average custom bimini made of Sunbrella and 1" stainless steel tubing. ...
My choices as I see them are:
Either way I would reinforce the bimini frame to make it more rigid and able to support additional weight.
- I can put two rigid panels over the bimini, one athwartships in front of the backstays...
- I can attach semi-flexible panels onto the bimini adapting the techniques described here: ...
