kimbottles
Very very nice Will.
You have a real future as a NA.
No need to steer? I didn't see radio-control gear, so I'm assuming the racing consisted of "put it in the water and let it go"?The rudder was a last minute addition to the hull to make the boat sail straight.
In every generation, there is a certain amount of "what's the matter with kids today?" When you see a group like Will and his classmates, you have to answer "not much". I felt the same way about my kids and their friends.
Meh. Pics or it din't happen!In every generation, there is a certain amount of "what's the matter with kids today?" When you see a group like Will and his classmates, you have to answer "not much". I felt the same way about my kids and their friends.
Area rule?The bulb looks to have the maximum camber very close to the maximum camber of the fin. I was lead to believe that Tis was a no-no as the maximum compression of the water occurred at the same point causing a very high pressure point at the bulb fin join, leading to most modern bulbs having their maximum camber further back well behind that of the fin.
I may be very wrong in the theory but I haven't seen a bulb like yours on any modern yachts, but it might scale differently.
Your building skills are top notch and inventive, well done.
Everyone in the class was given identical bulbs they were required to use. The addition of metal ballast to the keel was prohibited.Area rule?The bulb looks to have the maximum camber very close to the maximum camber of the fin. I was lead to believe that Tis was a no-no as the maximum compression of the water occurred at the same point causing a very high pressure point at the bulb fin join, leading to most modern bulbs having their maximum camber further back well behind that of the fin.
