mrgnstrn
I know there is some thumb-rule on the right length for spinnaker guys (AKA: afterguys, braces) but I can't find it at the moment.
Anybody out there remember?
thanks, M
thanks, M
Bam, Interesting.Be careful of spin sheets 2x boat length, especially if you are coming down the companionway - we used to go 2.25x, now its a solid 2.5x. Every boat is slightly different, but you can always make the lengths shorter - too short and life just sucks, right Kurty!
For what it's worth I have a pair of 10MM solid red Endura Braid afterguys for sale - Cheap! - 37' LOA. Brand new - never used!
Bam Miller
I'd be careful of going smaller than 5/16 dia. line because you've got to have something to hold onto (and if you have self tailing winches, they have to grab it too). That said, 3/16 SK75 (with cover is 5/16 dia line) should provide you with ample strength in a core, however, you can run the calculations yourself at the Wind Load Calculator.What is the right diameter of spectra/poly-doublebraid for a 35' masthead rig boat? Spin luff is ~45' and area is ~960sqft.
-M
Bam will have to confirm but my bet is he meant they were made for a 37' boat and are 56' longBam, Interesting.Be careful of spin sheets 2x boat length, especially if you are coming down the companionway - we used to go 2.25x, now its a solid 2.5x. Every boat is slightly different, but you can always make the lengths shorter - too short and life just sucks, right Kurty!
Bam Miller
Using Moonduster's rule of thumb, those afterguys are for a 25' boat?
Isn't 10mm overkill for that size?
-M
Actually, they were for an IMX40 and they were supposed to have been 2 of them, but instead 1 length of line was pulled, both ends tapered and spliced and then it was cut in half. Pretty much a dumb shit move from the word "go" and entirely my fault. MFO has 2 new guys and is much happier.Bam will have to confirm but my bet is he meant they were made for a 37' boat and are 56' longBam, Interesting.Be careful of spin sheets 2x boat length, especially if you are coming down the companionway - we used to go 2.25x, now its a solid 2.5x. Every boat is slightly different, but you can always make the lengths shorter - too short and life just sucks, right Kurty!
Bam Miller
-M
5/16" for afterguys doesn't bother me since we run lazy sheets and lazy guys.Actually, they were for an IMX40 and they were supposed to have been 2 of them, but instead 1 length of line was pulled, both ends tapered and spliced and then it was cut in half. Pretty much a dumb shit move from the word "go" and entirely my fault. MFO has 2 new guys and is much happier.
As for the 35' boat; 5/16" is the right size, but tough on the hands. 3/8" would be more expensive, but much more user friendly. I would assume that these are being used at sheet/guys as opposed to lazy sheets or lazy guys.
Supposed you had a bunch of "oops" and "Can't sell that for new" items that you wanted to get rid of; what the best way to go about it? I have always admired a "craigs list" kind of approach. Anyone have thoughts on how to go about it?
Bam Miller
Yeah, I had a feeling that the negatives of vectran would eventually catch up to the one positive it has over dyneema.The only consideration for guy size is the length of the pole and the basic geometry of how the afterguy comes into the pole from the shrouds. Some boats with really narrow shroud base and long poles are more likely to overload smaller diameter line. What's the magic formula - If you have a 3" pole longer than 14'; 3/8" might be right size, especially if you sail in windy areas. What kind of boat are we talking about? I and J? Penalty pole or not?
As for fiber, DSK75, in my opinion, is an excellent choice and will outlast and perform equally as well as vectran. Most of the stretch dyneema has is constructional elongation; remove that prior to use (like they do with Dux) and you won't notice a difference. We have almost totally gotten out of the vectran business, 2 spools vs 20 something spools of Dyneema. Our Portugal rope supplier, Alpha, says that no one in Europe is using vectran; even for halyards.
Case in point: We provided, through Scar Rigging, all the running rigging for Lucky Frog who just took 6th in the J80 Worlds; there was no vectran on the boat; it was all pre-stretched DSK75. Congrats to the crew of Lucky Frog!
One last thought - If you are setting and forgetting the afterguy; it probably doesn't matter what fiber you use.
Bam Miller
One final thought is that 3/8" line will grip better that 5/16" so you can use fewer turns on the drum, especially if your drums have been worn smooth from years of use. Your I and J are about the same as a J35, which I have often seen use 5/16". Pretty much personal preference based on the info provided. One final criteria would be how much beer do you carry when racing. If the answer is none - 5/16" is the choice, otherwise 3/8" will keep a happy crew happy.Yeah, I had a feeling that the negatives of vectran would eventually catch up to the one positive it has over dyneema.The only consideration for guy size is the length of the pole and the basic geometry of how the afterguy comes into the pole from the shrouds. Some boats with really narrow shroud base and long poles are more likely to overload smaller diameter line. What's the magic formula - If you have a 3" pole longer than 14'; 3/8" might be right size, especially if you sail in windy areas. What kind of boat are we talking about? I and J? Penalty pole or not?
Bam Miller
I=46.25', J=13.67', 3"OD pole, not a penalty pole. boat is a mid-80's C&C. sail in the mid-chesapeake.
So, on the fence between 5/16 and 3/8. I guess, if I get 5/16 and am uphappy, TFB. and I won't be un-happy with 3/8. so that answers it.
-M
