spraying nonskid particles onto rolled paint
phill_nz
899
internet atm
sometimes a professional doing something they have 100's of hours doing under perfect conditions
can make it look a little easier and better than a first attempt by an amateur will turn out
Grrr...
▰▰▰▰▰▰▰▰▰▰ 100%
9,688
2,265
Detroit
Covering it thoroughly with a shaker and then brooming it off after it dries will get you a great surface.  If you want to go faster, use a leaf blower set on high and held close to the surface about one hour after you roll and dust, then immediately paint your second coat.  Assuming you are using awlgrip with a recommended ratio in a normal temperature shop.
slug zitski
909
worldwide
Mix the griptex into the thinned awlgrip
Use the same thinner ratio that you would use for normal roll and tip
use a 50 50 mix of fine and coarse griptex , it give a better sheen
apply the mixed griptex , awlgrip with a short nap roller , not a foam roller or you will get edge tracks from the roller
Once the panel is coated take a fresh , dry roller and roll the painted surface again
this second dry roll removes the excess paint trapped by the griptex particles
if the dry roller becomes saturated , replace with a new dry roller
spray application as described In The   Video is a gigantic mess .. particles everywhere
when rolling non skid  paper off the perimeter of the panel to catch roller splatter
the technique described is how pro painters apply non skip to mega yachts
