Loose Cannon
Anyone have the details on the upside down sprint on the front page? Looks like it did a wheelie and went over backwards...
Screecher in the jammer?I'm working on a thorough debrief and will post soon. Short answer in the meantime - it was a pitchpole
Having done this myself in a mkII. If the water is shallow enough and the bottom soft enough the boat will not go turtle.It looks like they're just about re-righted. I see a boat on the far side and personally know they turtle.
I thought of that after I posted, they may just have dug the mast in. You're right. I have been on a 27 that turtled pretty quickly, as in it never paused and know the 31 turtles quickly as well. Hope they recovered it with minimum damage.Having done this myself in a mkII. If the water is shallow enough and the bottom soft enough the boat will not go turtle.
how do you turn them over?I thought of that after I posted, they may just have dug the mast in. You're right. I have been on a 27 that turtled pretty quickly, as in it never paused and know the 31 turtles quickly as well. Hope they recovered it with minimum damage.
You set up a bridal forward and aft. Hook it to a powerful tow vessel. Pull the boat into the wind/seas stern first as fast as you can and the sterns will dig in causing the boat to flip back over.how do you turn them over?
sorry I meant the first part, how do you flip one in the first place?You set up a bridal forward and aft. Hook it to a powerful tow vessel. Pull the boat into the wind/seas stern first as fast as you can and the sterns will dig in causing the boat to flip back over.
both ama's?Just the opposite of righting it. Drive it hard until the bows dig in, and over it goes...
sounds like something you could do offshore, where was that flip and what sails were up?yep, that's the way to do it. Cat's usually flip sideways and because of the Tri's increased righting moment, they usually pitchpole.
I did it in sarasota bay in 18kts with gusts higher, just got hit at the wrong time the wrong way. Still won the class at the regatta though.sounds like something you could do offshore, where was that flip and what sails were up?
Takes one to know one...Damn multihullers flipping those dangerous boats again
whoa - what happened to the rig? & who was crazy enough to swim underneath with all those stray ropes to undo the bolts of the floats? That seems a bit dangerous considering they are relatively easy righting using the recommended standard technique (as mentioned by JoeyG) ... but then I wasn't there and don't know what else was going down ...And here's a vid of the re-righting
