The great unwashed
I own a Colgate 26 which is in the water here in Hawaii 24/7/365. Obviously tropical salt water year round is the worst possible environment for metal rigging. I lost the mast about 10 years ago—the swaged fitting on the bottom of the windward lower pulled out and the mast snapped at the spreaders. Inspection showed that the wire inside the swage had rotted away about 1 inch into the socket. No way to tell without x-ray inspection. A little extra tension and boom, no more mast.
It’s about time to replace the new standing rigging (the old rig had 10 year old wire on it when it failed), and I wonder about a couple of things:
1) It blows a lot harder on average here in Hawaii than it does on the East Coast, the area for which the boat was designed. Can I upsize the standing rigging wire, or is there some complex equation taking stretch etc into account that would be violated if I went up a couple of sizes on the shrouds? I know that the weight of the rig would increase, with more heel etc., but I’m not racing.
2) Would Norseman style fittings at the bottoms of the shrouds be less likely to encourage corrosion in the wire? Is there a minimum wire diameter for such fittings?
Thanks!
Thanks!
