PM me. Batch 1 is literally being produced right now. I'm overseeing a hull deck bond job at 9am tomorrow.seriously, where do I send the deposit?
cheers -- make sense.. automagic is good.atefooterz said:With the right wing mast section then boom tension is set when fitted, fat top geometry would mean a squeeze on the main would help any out of the ordinary power for low mode, med to high would be auto via mast bend & batten stifnress . Being a foiler you need to keep main flat n fast with leech by design rather than user tweaked so much, my guess.ah ok - so if the wishbones go to spreader tips.. how do you control leech tension?
EDIT: Obvs the boom angle does not allow leech rise with freed sheet as much as a horizontal boom ( hopefully you already know that)
low mode - you have sheet to play with, so can adjust.I've read this "sentence" a dozen times & still can't decipher it. Can someone please translate it?With the right wing mast section then boom tension is set when fitted, fat top geometry would mean a squeeze on the main would help any out of the ordinary power for low mode, med to high would be auto via mast bend & batten stifnress .
sentPM me. Batch 1 is literally being produced right now. I'm overseeing a hull deck bond job at 9am tomorrow.seriously, where do I send the deposit?
DRC
Ahhh, dad's typos again!Also dad made a typo. It's just under 8 quare meters of sail area.
DRC
Looks like at least a 9.5 depending on the Russian judge scorewhats it rate?
