SV Seeker
Zonker
7,473
Canada
I'm going with red arrow one to chafe through first.
I was thinking we needed a betting pool for "first capsize". But then there could be "sinking", "severe grounding with damage", "big wave causes entire pilothouse to short out", "utility pole masts fail" etc. etc. Too many choices.
Zonker
7,473
Canada
How much slower than "virtually stopped" can you be?
The camera never stays on the chain long enough but it looks like it's about 3-5 ft/min (a windlass should be about 30-60 ft/min)
Wobbles are fine with directly coupled motors according to Doug.
But everybody says it's a problem. (they are right, something would eventually break)
But he can't bring himself to admit that, so explains why he added a chain coupler (a flexible coupling element) is because "he was tired of people complaining"
The cognitive dissonance is strong with this one.
Voiled
378
Some tubing chafed trough and caused a leak in the aft cabin at the beginning of his trip downriver already.
Timestamped:
Zonker
7,473
Canada
Am I correct in assuming that if he could fit the shackle through the chain it's undersized?
Well I think that's the most put together part of the boat. Actual safety wire.
S.S. shackles underwater are dumb with galvanized chain against it but it's going to be OK for a long time. It just erodes the galvanizing because the zinc coating becomes an anode for the stainless.
epoxypete
240
The cognitive-nearly-complete-disconnect will only grow as he disregards basic respiratory precautions when working with two part coatings, particularly inside the boat! Didn't his mama teach him abou.....oh I forgot....he was not raised by a mother who was also a woman.
Like how he states his pathetically slow anchor winch now will go twice as slow as before but be more powerful. Since when has Dugg ever got anything right in the first place?
2_Hulls
6
Auckland, NZ
It's even worse that than - I sometimes hear people of the British species refer to two by fours as "four by twos" which means that they have some magic where by depth is halved but width is doubled. I can't pretend to understand it and it's a miracle the Spitfire turned out as beautifully as it did.
Funnily enough even though we are metric here, 100 x 50 is often referred to as 4 x 2.
Mainly by old farts like me..
toddster
1,195
The Gorge
Wire nuts ≠ strain relief in any case.
And btw, “imperial” ≠ SAE. That’s something else completely different. Sadly, many cheap Asian fittings on the interwebz are actually “imperial” and don’t fit any fucking thing.
