SV Seeker
Foiling Optimist
370
Vancouver BC.
They have to be imperial. Who else on the planet would use them?
FKT
There's a Kelowna BC based electrician, @karlythesparky, on Instagram. She posts about electrical installations, but is inescapably not a dude, which of course drives the pompous mansplainers around the absolute bend. Anyway, they apparently truly lost it recently when she discussed marettes. Marettes is the Canadian term for wire nuts, which we do use, though probably less than in the past. Apparently the international mansplainers don't know they're called marettes in Canada. She makes me proud to be a British Columbian.
Fah Kiew Tu
Curmudgeon, First Rank
10,971
3,904
Tasmania, Australia
Actually I've been known to use them myself but only shoreside, on 240V power wires, and suitably enclosed in a junction box. There are none on my boat.
Bet Doug didn't use tinned copper wire either.
FKT
opcn
157
Nordland, WA
Main reefed way down, crawling along well under 5 knots, leaning over like she is being pushed hard, not even enough wind to whip up whitecaps.
epoxypete
240
He was sailing nearly dead down wind at 3.1 knots. If he came to a stop over say 100 feet that would take ~38 seconds (if I remember the math from my physics course in 2007) or 0.43% the force of gravity, equivalent to what you would experience standing a quarter of a degree off of level. If it was 10' until the stop just multiply by ten as it's still small enough for the small angle sine approximation and it feels like the floor has tilted back 2.5°
As much as I enjoy figuring out stuff as much as the next guy, you may be torturing yourself needlessly with the calculations dear opcn. You see, Dugg is nothing but an ignorant bullshitter attempting to grift his way through his retirement on his BSO. His BSO is not fit for purpose.This BSO is not set up, nor will it ever be, for single handed sailing. It does not and cannot sail properly. The motoring ability is severely limited and likely to go into full failure mode if really pushed, as in an emergency situation. Any number of welds and other assemblies are suspect to fatigue failure since they were poorly accomplished by someone who,despite 15 years of learnin', has simply not learnt a damned fucking thing about proper welding.
Dugg is now getting perilously close to his final life learnin' lesson. It will occur either in the large bay he is presently anchored in, if and when a hurricane comes through, or the fateful day he goes beyond the sand dunes south of him and out onto the gulf.
It is a shame this is not a true single handed BSO, for it would matter not a bit the day Dugg takes off alone out into the gulf. Innocent lives will not be tested.
billsreef
800
Miami
They are fine so long as you've got single conductor wire and you put them on and leave them in place for the next 8 decades or so.
And somplace that is free of vibration and movement. Usually want that place to be protected from water as well.
Sail4beer
Starboard!
I think it could blow over in a gale or heavy squall with the sails down and at anchor. The deckhouse will peel off at 90 degrees taking the captain and crew with it before the Coast Guard can be summoned.
opcn
157
Nordland, WA
That is a lot of heel for so little wind. What are the bets for how much wind to roll her over and turn turtle, 10kts or more?
I don't think it's as bad as that. She was out with a most of her main the day she grounded and that was close to 10 kts. My guess is 25 or 30kts for a full blowdown. I think she will heel over and take on water first. Especially if they take her out to anywhere with and swell.
cb32863
Maybe he can put that dinghy(?) on slides and a winch system so he can shift the weight of it to the high side. That would be so ingenious and show once again how amazingly smarter then everyone else he is. How heavy is that thing and how does one get it off there? When she is about to go over you release the straps?
