Better to avoid problems than to solve them. You'll never live long enough to make them all yourself.Amazing how the sycophants chime in with "amazing you can solve all these incredible problems!" when the problems are all self-inflicted.
He didn’t make it. Someone gave it to him. He then took a grinder to make it fit to his crappy and lopsided wheel.Wonders will never cease. I actually like the octopus on the wheel.
Of course, everything else, including the owner, is fractally fucked.
That makes belt driven side wheels an option! Bearings, prop, shaft and rudder no longer matter. If he can independently reverse a wheel he can even maneuver. The wheel housing can double as outriggers. Epic welding possibilities overcome several critical design flaws. Maybe he can spin it as a an homage to Great Eastern. He can rename it the S’Eastern (Subpar Eastern)Both outputs are unused.
one of his okey cousins is bound to have an old D7 cat to donate here, just drop the engine and drivetrain into the engine room, weld off to the right height and with a coupla holes in the side..........voila..... instant paddle wheeler, linking drive train to helm should take up close to a year or so of "Logical thought" processes thoughThat makes belt driven side wheels an option! Bearings, prop, shaft and rudder no longer matter. If he can independently reverse a wheel he can even maneuver. The wheel housing can double as outriggers. Epic welding possibilities overcome several critical design flaws. Maybe he can spin it as a an homage to Great Eastern. He can rename it the S’Eastern (Subpar Eastern)
Dugg, if you read this: It‘s important sure the paddle shafts have -5’ camber (toe out), so seawater spray can lubricate the seal.one of his okey cousins is bound to have an old D7 cat to donate here, just drop the engine and drivetrain into the engine room, weld off to the right height and with a coupla holes in the side..........voila..... instant paddle wheeler, linking drive train to helm should take up close to a year or so of "Logical thought" processes though
