Israel Hands
looks suspiciously like a light polekinda odd seing a mast with a hole that big in it....
No doubt. I would've thought using the part above the hole might be prudent, but I didn't sleep at a holiday inn last night.looks suspiciously like a light pole
Almost as big as the hole in Doug's head...kinda odd seing a mast with a hole that big in it....
Could be that the weld is a carefully calculated safety "fuse." The mast will snap off at the tacky weld before it folds at the hole.kinda odd seing a mast with a hole that big in it....
The outside diameters are different, so it might be inserted like a sleeve, except that the alignment is cockeyed looking at the stub. Doesn't appear to have much cross sectional area in the weld. Is there some element of structural integrity that I am missing?
Doug has tried to become a boatbuilder for 15 years now.
Look at the welding job at the base of the mast. Doug, or someone else, ran a grinder horizontally around the flange to clean up the weld for some reason and ate into the spar just above the weld line. That’s not a good idea if the spar comes under heavy compression and flex simultaneously.The outside diameters are different, so it might be inserted like a sleeve, except that the alignment is cockeyed looking at the stub. Doesn't appear to have much cross sectional area in the weld. Is there some element of structural integrity that I am missing?
It was one of the few jobs in the last couple of months he did without assistance.Look at the welding job at the base of the mast. Doug, or someone else, ran a grinder horizontally around the flange to clean up the weld for some reason and ate into the spar just above the weld line. That’s not a good idea if the spar comes under heavy compression and flex simultaneously.
Nobody thinks he isn't. And I doubt anyone believes he is disposing of his black water tank content in ways he should. But let's not spill that part of the discussion this way.Is he dumping that bucket in the lake?
Contrarianism has an important role in Game Theory. And investing -- the Big Short is the textbook example of studying what others are doing, then making an opposite play because you think you know something the others don't (e.g., CDOs are wildly overpriced relative to their real asset value.) If we view social media as a sort of stock exchange where eyeballs (or engagement) is the currency, contrarianism within a structured economy can drive engagement and skim eyeball profit. We are talking about Doug right now, meaning Doug is capturing engagement.Like so many of these nitwits, Doug is arguably anti-science in that he disdains the body of knowledge that he could leverage to his advantage. They think themselves free thinkers as they "do their own research" but ultimately reach wrong conclusions due to their lack of understanding. Of course anybody trying to helpfully point anything out that doesn't fit their viewpoint is dismissed as a naysayer no matter how experienced.
And yet today there are so many that think and behave this way. It's interesting that this trait wasn't weeded out of the gene pool way back on the savannah. Perhaps it goes hand-in-hand with the ability to believe in a supernatural agent and the survival advantage that enabled.
Man... time for a martini....
We can now return to the concept of the In-Group Contrarian (hereafter IGC). Anyone who has observed social media platforms, especially Twitter, will know the type. This is the person who, precisely when mimetic snowballing is in progress, attempts to apply the brakes. What’s important is that this figure is not simply an outsider to the group, in which case they could probably be ignored, but instead claims to share the group’s goals, beliefs, etc and merely objects to some aspect of this manifestation of them. The appearance of this figure is as predictable as the mimetic snowballing itself.
