Santanasailor
Charter Member. Scow Mafia
We are using a 30lb thrust trolling motor on Anna Eleise. Finally sold the, always needing an annual carb rebuild, small four cycle outboard from a normally very reliable manufacturer. It had not run in several years and virtually gave it away. Still, while the electric trolling motors are not infallible and usually require replacing about every two to three years, the replacement cost is less than than a carb rebuild.
I suppose the best plan would be for a small inboard electric. There is certainly plenty of room under the Santana’s cockpit. However, the practical solution, cost wise, and the direction we will go is to a 4 or 5 hp Tohatsu. It will do double duty on our Jon boat that we like to fish out in the cove we live on. Weight is the key issue and that will decide the actual motor chosen.
Still, the old Evinrude, sits in our shop for years, put it on a boat, pump some fresh gas in it, give it a few pulls on the starter and she chugs away. Being an 8 hp, with a 25 inch shaft, It is way too large for the Santana.
People can whine about how dirty/nasty two cycle outboard are, but never have I heard many complaints about old fashioned reliability.
