... and the engine is not at full throttle at lower rpm and is not burning full fuel rate. It's not that the engine "is" producing more power at lower rpm, it is that it "can."Thanks, you just supplied graphical proof of what I said that in my experience a diesel does not need more power at lower RPM's the diesel produces more than than the prop needs.
JJ
Just being pedantic for a moment, diesel engines do not have a throttle - that is a gas engine device. They have a governor, the lever controls the governor set point. Fuel delivery is controlled by the governor, it will provide just enough fuel to reach the set rpm (or, if overloaded, an excessive amount.... a problem electronic governors do not have).... and the engine is not at full throttle at lower rpm and is not burning full fuel rate.
Does the rated power tells you the whole story ? I have a bit of experience of underpowered boats. IME on a true sailboat that can actually sail upwind (as opposed to a motorsailer) when at a constant cruising speed you tend to not load your engine heavily for obvious consumption and noise issues so don't notice if it is reasonably underpowered. On the other hand when the engine is a bit small for the boat it really shows when you are trying to convince the boat "do something it doesn't naturally want to do" which tends to happen in tight areas. The engine will take time (may be actually it is just a second or 2 but it feels like an eternity) to take its revs. Obviously you can often plan ahead to avoid these situations but for instance with a side wind blowing you off it is nice to come in with some speed and kill it right at the end. If you try to do this on a 1980s IOR boat equipped with a 1GM and a folding prop, obviously this will not end well... solution is probably to find a less challenging spot.The gap between a diesel's power curve at a given RPM and what a fixed blade pitch prop can absorb is a physical reality.
If you didn't have a gap you couldn't accelerate either![]()
Yes, most modern sailboat diesels have more power than required to reach hull speed. There it lots extra for adverse wind/waves adding resistance.
You're describing an underpropped setup: your diesel engine was producing as much power as the prop would absorb. So yes, if you are using a prop that's too small for the engine then it will never produce the rated power. If your prop is the right size then it absolutely will - typically you size the prop to absorb the rated power at max rpm.I agree with all the above points.
A given diesel propulsion engine connected to a prop is almost guaranteed to be far from its most efficient rpm.vs.load, and very likely never actually USES or DEVELOPS the rated power: the prop is turning far too slowly to absorb that much power, and so it does not consume the fuel and does not generate the power that is printed on the label.
That is why my motor using 4.5KW provides identical performance to a motor whose sticker says it develops 27 HP. The diesel never generated 27 HP, it actually clearly generated 4.5KW or 6hp. It was MUCH larger than needed.
I also agree with the observations where having more than enough power can be handy in certain situations. However, the prop still isn't turning anywhere near fast enough to generate the label HP in those situations either.
Hence, while KW being different from HP is fake news, what is certainly and trivially demonstrable is that a much smaller amount of electric power consumption is equivalent to a much larger rating label on a diesel.
......................That is why my motor using 4.5KW provides identical performance to a motor whose sticker says it develops 27 HP. The diesel never generated 27 HP, it actually clearly generated 4.5KW or 6hp. It was MUCH larger than needed............
......what is certainly and trivially demonstrable is that a much smaller amount of electric power consumption is equivalent to a much larger rating label on a diesel......
aha, and that's why we have this thread. because diesels suck so bad. lol.You are likely making a comparison between a poor design and a good one
I spent a lot of time matching engines to fixed props on vessels where it's important to get it right.aha, and that's why we have this thread. because diesels suck so bad. lol.
Yep. I like the idea of electric drives but this biz of a 10kW electric drive is the same as a diesel engine of 3X the (theoretical) output just because it's using magically more efficient electrons instead of carbon is pure wishful thinking, to be polite.aha. that's why we have this thread. because diesels suck so bad. lol.
This is not certainly not true and not demonstrable. You've already said you used the same prop for a 27 hp motor and a 6 hp motor. If that worked well for both, we would only need one prop for every motor on every boat.Hence, while KW being different from HP is fake news, what is certainly and trivially demonstrable is that a much smaller amount of electric power consumption is equivalent to a much larger rating label on a diesel.
Z............ electric motors typically have max torque at 0 RPM. So instantaneous throttle response at low speed is very high. Great for docking a boat.
I crewed on an O 40 T-Pac waay back when they were brand new. I am certain we could motor a lot faster than 6 kts. Probably pushed 8 kts at high end.I'm assuming you changed props? Were you ever able to run the diesel at 3600 RPM?
Certainly a strong contender, but first the rating committee want to know how many 3-strokes and 6-strokes he's had.you win?I've had four 4-strokes and five 2-strokes.
