No 8 wire and some kiwi boat builders will have that fixed by Tuesday, earlier if you don’t mind the paint not matchingThe should give Core Builders Composites in warkworth a ring, there excellent at this sort of work
Crikey, looks like the integrity of most of the hull has been compromised. My optimism level has just plunged.
I’m guessing it was a hydraulic ram sheering off it’s mounts then continuing through the side of the boat.i wonder if there was something left in the sewer that had some weight... which became inertia and punched this massive hole?
Ram for what?I’m guessing it was a hydraulic ram sheering off it’s mounts then continuing through the side of the boat.
Gravity will do that without a ram holding them up.Ram for what?
Foils seem to be in the down position
Sorry.. in the down position while sailing, not in the fully down position when on the cradleGravity will do that without a ram holding them up.
If they haven’t destroyed the mold for Patriot they could rebuild the port bow section and fly it out to NZYep, stick a fork in Patriot its cooked.
Defiant or withdraw.
