I’ll hang it on Dean: he had a comfortable lead; he ignored the advice of his main trimmer; he took the high risk choice over the low risk. Then bad luck pounced - a lefty, a runner left on, and pressure.Hanging Deano out to dry over this is bullshit, his job was to drive the boat fast which he was doing.
Do you think this team had not done or practiced such a move before?
What made this go pear shaped was someone left a runner on resulting in the main loading up in the bear away.
TH should not have his head down grinding there is too much shit and puffs that are not being noted and adjusted for, a tactician has to have his head out of the boat.
Well said Wethog, for what it's worth totally agree with y'all....I just think back to just before the mark rounding when voices started going up octaves and wanting to hear what was going on but we couldn’t because Kenny and that McIver dolt wouldn’t stop talking. Sure it’s their job but...
WetHogh34r:
watch the sterncam feed - you can hear everything...I just think back to just before the mark rounding when voices started going up octaves and wanting to hear what was going on but we couldn’t because Kenny and that McIver dolt wouldn’t stop talking. Sure it’s their job but...
WetHogh34r:
Hindsight is a useless tool that does nothing but confirm history...... If.... woulda / coulda / shoulda does nothing but get you an audition for a frikkin talk show.....if Dean had gone for the low risk path I think it’s likely they would have finished the race in one piece
Who's the Skipper?I’ll hang it on Dean: he had a comfortable lead; he ignored the advice of his main trimmer; he took the high risk choice over the low risk. Then bad luck pounced - a lefty, a runner left on, and pressure.
if Dean had gone for the low risk path I think it’s likely they would have finished the race in one piece.
Wrong, Barker is the helmsman, Hutchinson is the skipper, at least according to the official rosterTrue but in the end the wheel is turned by who. The skipper
If a heavy battery rams through it it might not be straight anymoreThat looks nothing like the bit that was delivered to the base earlier
More likely some heavy equipment, like a heavy battery, shoot through the hull (if that hole was not made bigger and square by the divers for whatever reason)Yeah 100% ram pushing through the hull on touchdown IMO
And review tactical decision making.What a job list
pull out all the internals ( Hydraulics and electronics)
fix the hole or holes
fix the internal systems
test the internals
reinstall internals
test boat
Without a comms set that was working evidently.One of the grinders.:huh:
Dean Barker has as much experience sailing large foiling sailing boats as anyone in the world. He was at the wheel when the first AC72 started foiling.Sailing normal monohulls, where Terry and Dean have most experience, it is often considered safer in extreme conditions to tack and then bear away, rather than bearing away and gybing. So, they may have been acting instinctually. Paul was the only one with extensive foiling success and experience. As in this example, there isn't the time to debate, or even for the tactician to pass the information to the helmsman (Particularly if you leave it to the last minute, as they seemed to have). Paul, and his foiling instincts, should be driving .
