The Ocean Race 2023 leg 2: Cabo Verde to Capetown
Tom O'Keefe
Malizia way off the Pace. Even though it's still early the prognosis for them isn't great. History shows if a boat is off the pace or too extreme it doesn't end well. Having said that Team Guyot are now in the lead but a long way to go.
Guyot are closer to Rum line. But, Biotherm are in the lead to the traditional path south. I'd still rather bein Biotherm's location than any other. That's why I asked about what happened last leg.
despacio avenue
330
Alaska
11th Hour going better in the slow stuff than I would have thought. I guess they are carrying the kite. I assume their J3 is still gone, so maybe decision to bring the kite was probably an easier one.
I say that, but tbh, not actually sure what the rules are on how many sails they can bring?
According to Kevin Escoffier on the posted video, the boats are allowed to carry 8 sails.
Chasm
521
The sail rules for the IMOCA are interesting.
6.5 By 1630 on 6th January 2023, IMOCA 60 Teams shall nominate up to eleven sails plus one
storm jib
. Where an IMOCA Team does not nominate the full eleven sails at the Assembly Date,
it shall nominate the remaining sails before they are used in the Race.
Only these nominated
sails and sail bags shall be carried, hoisted or used on the Boat at any time after the Assembly
Date. Sail materials used for nominated sails shall not include carbon fibre.
6.6 IMOCA 60 sails must be fully measured, branded and certified before they can be nominated.
After nomination, IMOCA 60 sails may be recut or reshaped, with the limitation that no more
than 25% of the original area of the sail material shall be replaced.
6.7 An IMOCA 60 Boat shall carry a maximum of seven sails plus a Storm Jib on every Leg. An
IMOCA 60 Boat shall carry a maximum of seven sails on an In-Port Race but shall not change
the sails on board after leaving her mooring immediately before the In-Port Race.
So teams have the option to add a late sail and to modify sails between legs. At least there is the option to make major sail repairs without jumping through hoops like last round.
Schakel
Dayboat sailor
11 th hour racing and Holcim PRB match-racing in the middle of the Atlantic.
1.1 nM distance between the two
dg_sailingfan
973
Augsburg
Once again that so-called Super Team 11th Hour Racing with Navigator Simon Fisher gets outsmarted by HOLCIM-PRB and Escoffier/Goodchild.
According to the 09.00am UTC Tracker Update today HOLCIM-PRB are now about a mile dead in front of 11th Hour.
Don't get me wrong but I think Simon Fisher or SiFi has lost his juice here.
Rocky
37
Apparently Malizia has decided to head to the carribean to do some cruising. The more age appropriate choice for Yann Elies and all the crew just wants to see Rosalin Kuiper in a bikini diving into clear turquoise water anyway. Seems like the smart move at this point.
Rocky
37
Maybe additionally to the large accommodations they should have gone for a shallow draft version of their boat as well, 4.5 meters seems rather unpractical in the Bahamas.
Herman
1,942
The Netherlands
Weather routing Jan 28th
The big picture is in pic 1 with Brazilian navy synoptic overlay (00UTC). I have manually removed most of the METAR zone lines in order to de-clutter the screen. The ITCZ is plotted in orange lines. Compared to the location of yesterday, the ITCZ is more or less stationary. In the middle it moved a bit south (+/- 25 nm).
Pic 2 has the NOAA IR NWS colour layer added indicating the cloud activity @ 00 UTC. Zoomed in to the 1040 UTC boat positions. Biotherm is less than 187 nm north of the very high clouds aka north side of the ITCZ. The blue and red colored clouds indicate colder / higher clouds which you want to avoid if possible. These can primarily be seen closer to Brazilian and African coasts.
Pic 3 has added GFS wind barbs @ 12 UTC from the 06UTC run.
The fleet has been dispersing in the past days. And different strategies are clearly emerging for crossing the ITCZ. The fleet is +/- 208 nm dispersed west to east. Do not follow the leader but pick a strategy / lane. Very interesting choices.
Malizia is by far the most western boat and has thus firmly invested in the west. With +/- 105 nm additional longitude compared to 11th Hr and Holcim-PRB.
On the other side of the fleet Guyot has firmly stayed east, closer to the rhumbline from Cabo Verde to Capetown. Malizia and Guyout are +/- 208 nm separately by longitude. And +/- 264 nm laterally.
The top-3 boats are still relatively close to each other, max distance is laterally 26 nm between 11th hr and current leader Biotherm. And positioned between the flanking Malizia and Guyot.
To put the obvious; only the top-3 are enjoying the same weather and Malizia and Guyot enjoy separate wind and pressure. This opens up also opportunities.
So which strategy (west – middle - east) is the fast lane?
Computing with 3 hr timesteps calculation for GFS 16 days ahead 1,25 degrees resolution and 06UTC run gives an interesting answer.
Pic 4 has the weather routing for the 5 boats. Malizia clearly projected far more to the west than the other 4 boats that all follow more or less the same route.
Pic 5 has the ETA table which indicates that for the top-4 boats their finish is projected within one (!) hour @ Feb 11th in the evening. Malizia projected a day and a half later @ Feb 13th early hours. All boats still projected to enjoy a LP ride eastward. But as Malizia is projected to drop off very quickly from the LP compared to the other 4, with following less winds than for the pack, she is projected to bleed a considerable additional amount of miles. See pic 6 with red arrows for Malizia and the pack of 4 and the various HP and LP zones in red marked.
wildbirdtoo
455
UK
Fascinating! Thank you Herman. I guess it will really depend on how they manage to cross the ITCZ.. although the middle three boats will probably experience similar conditions. But I guess even a couple of miles can make a difference in squalls and lulls etc. This is the telling next period, I guess.
TheDragon
1,571
East central Illinois
The ITCZ just keeps expanding if the forecast on the TOR tracker is to be believed. Malizia can barely gybe at 90 degrees, compared with 110 for Biotherm, must be super frustrated. But then, Herman has them doing time travel to arrive Jan 13, so maybe they have a secret mode (just teasing, Herman!)
Herman
1,942
The Netherlands
Thx, corrected in post.
