The Ocean Race 2023 leg 2: Cabo Verde to Capetown
LeoV
4,750
The Netherlands
Ah, used Quickscat in the past, they gave sea surface winds. That satellite is gone. though for some reason Ascat was not surface winds, but presentation of wind at a higher level. But after reading Herman linked material, yep it is surface winds.
Nice.
Was looking at Ascat when they went through doldrums, and some got a very light wind, a bit stronger wind, then light wind passage. The others only light wind.
Edit, looked back on tracker, looks like it was Guyot that was positioned in the best spot.
Herman
1,958
The Netherlands
Weather routing Jan 31st
Pic 1 has Sat IR overlay 08:20 UTC pass and 08:40 UTC boats positions with max sat zoom. The fleet could be on their way to the exit of the woods. But still some active clouds to their south, but these are yellow and not blue or red colored. These clouds are +/- 70 nm south of Guyot. The boats have been picking up speed in the past hours. Double digit boat speeds noted again for all boats @ 09:00 UTC. Guyot as most eastern positioned boat has done the most nm in 24-hrs (209 nm) and has been expanding her lead. Pic 2 with Brazilian navy synoptic chart also suggests that the worse part of the ITCZ could be over.
When the boats are fully out of the woods tomorrow, I will run a new weather routing.
ET1
153
Germany
Looking at the tracker it seems that the eastern boats are all going West. Pushing the tracker 4 hours forward it looks like the western ones will get new breeze wile the eastern ones are going to run out of fuel. Still exiting imo everything still can happen.
dg_sailingfan
986
Augsburg
No, Team Europe will be fine I think!
Tom O'Keefe
The other boats will have a faster angle as they converge. This is why in general, west is best.
Usually, the easiest path through the Doldrums is West. But, so far Guymont has done very well cutting the corner. The boats in the West will have hotter angles. But, they will also have more distance to sail. Shaving corners is a really good thing. The downside is Team Europe could still find a blind alley. Only time will tell. But, bravo for taking the risk!
Fiji Bitter
I love Fiji Bitter
4,965
1,689
In the wild.
Tracker had all boats doing 13's or more and Bio doing 9,,, They lost a heap on all over the last bunch of hours
Biotherm did a little jiggle a while back, perhaps. But 11th Hour has been going substantially slower, and slightly lower, than all others for the last 4 hours:
11th: 14.4 kts @202
Biotherm: 15.2 kts @200
Malizia: 16.6 kts @198
Holcim: 17.3 kts @193
Guyot: 17.8 kts @196
Thanks for that, possibly they are not completely out of the doldrums, and into the proper steady trades yet. Just my guess...
terrafirma
1,454
Melbourne
Team Guyot Environment now out to a 50nm lead. Holcim 2nd. Will be interesting to see how Guyot perform now all the boats are in steady breeze? Can they hold off Holcim with such a long way to go.?
Varan
2,179
East won this round. How about the next high? Dare you continue west towards Rio de Janeiro?
