wildbirdtoo
457
UK
I doubt it's a gamble. Seems like a cost cutting measure. Noone can seriously think boats without foils are competative after the last round.
Well, I seriously think a Jean le Cam non foiler could be competitive. He was 4th last time even with conservative sailing after the hull partial delamination. They say it was "unusual" conditions for the VG last time, but also say the same about this TOR, so maybe more variable conditions are becoming the norm. I'm itching to see how Jean's new designed non foiler performs. "Yes we Cam" in his capable hands was no slouch.
JonRowe
1,168
Offshore.
Notice how they use the self-regulating "mustache" foils because they have a much wider groove. All minis with foils since have let go of the AC foils. I think this speaks for itself.
No mini can use full AC style foils, because they have to be "dagger foils" (retract into the boat) to meet the rule about starting, so this preferences the weird curve shaped boards because they are simplier, where as the T foil style foils have to cant and retract. I believe J Thompson is still sailing his T foil mini, so theres at least 2 racing T foilers with only the new 1067 not using T foils? (The old Arkea went back to no foils but thats a different story)
Jean Le Cam seriously thinks they are competative and more seaworthy. He was 4th in a old non foiler, and is leading the charge building two new scow like non foilers. I don't think he'll change the classes mind though.
Herman
1,958
The Netherlands
Weather routing March 27th (1/2)
The AIEZ got moved again I noted, to the north. Updated accordingly.
Tried 2 different sources but ECMWF latest GRIB file available atm was from yesterday the 18Z run and a bit too old to use imho.
Pic 1 has ASCAT 0254Z and GFS wind
Pic 2 ASCAT 0254Z and GFS zoomed to CH. Seems to fit for wind speed and direction.
Pic 3 has Sat IR color 0648Z with HPs / LPs and a front as synoptic chart.
Pic 4 Sat IR color 0647Z and GFS wind and pressure. Seems to fit again.
The wind has come down as expected. Sea state is improving now the wind has gone. Team Malizia and Holcim-PRB should have currently +/- 4 meter significant waves according to WW3. Improving to +/- 2,5 m sig waves when rounding Kaap Hoorn.
When backtesting the Wx routing of yesterday against the 0630Z boat positions both Biotherm and 11th Hour racing are clearly behind projections. This could be bcs the light winds have come earlier than projected. Both TM and Holcim-PRB have chosen to stay more south than projected in order to have a layline past CH and do just 1 gybe.
Pic 5 Backtesting polars boats 0630Z against projections yesterday
TM just gybed NE, as projected by the GFS routing. See pic 6 Wx routing zoomed 07Z.
Pic 7 rounding Cape Horn Team Malizia in the evening of March 27th. Rosalin will have enough daylight for her picture. Boats will probably get closer than plotted now, the no-go area is set at 6 nm south of the lighthouse.
Pic 8 rounding Cape Horn Holcim-PRB in the evening of March 27th
Pic 9 Wx routing
Pic 10 Wx table. The 1st two boats will battle it out. See my next post.
Herman
1,958
The Netherlands
Weather routing March 27th (2/2)
That LP that I mentioned yesterday for March 28th should be OK for TM and Holcim-PRB according to GFS for the position around 28th 0505Z see pic 11. This LP should start developing around 12Z today above Ushuaia with 982 hPa. And intensify quickly while moving SE. By the time that Biotherm and 11th Hour Racing have rounded the Cape the LP has left the building and there will be no elevator ride north like the 1st two boats are projected to enjoy. Subsequently the lead by the 1st two boats gets bigger. And will have to battle it out for the leg win.
Sea state will be more or less OK according to WW3 (+/- 2 to 3 m sig waves) as it is a bit a windward shore and waves cannot build as compared to the western side of South America.
Pic 11 Situation March 28th 0505Z
Fiji Bitter
I love Fiji Bitter
4,965
1,689
In the wild.
Well, just 1 hour until forum maintenance close down.
Had a quick look at Facebook and Twitter, but didn't find much there.
Looks like the app with the tracker and Latest/From the boats will be the best place to follow the Kaap Hoorn rounding.
Anyone with a better idea?
The boat blogs perhaps, if you really need to procrastinate...
huey 2
2,242
syd
Infomercial from Seahorse
The Holy Grail​
The Holy Grail
Visit North Sails Performance
Dry and light! In two short years North Sails Performance clothing has firmly established itself among the most elite technical clothing suppliers... with the benefit of some pretty high quality assistance!
A dry bum is one thing that’s very pleasant about wearing North Sails Performance foul weather gear. The other is just how light it is.
When North Sails Performance director, Nigel Musto, set out to create the best sailing gear ever seen, or worn, his primary objective was for the wearer to be comfortable and dry. Truly, properly, dry even after hours on deck in heinous conditions. However, one nice sidebenefit - the light weight of the North Sails Performance range - has ended up becoming one of the biggest draws for customers. More of that in a moment.
It has been a whirlwind entry to the market for the new range of highperformance offshore clothing. ‘Our two years have been outstanding for us,’ says Nigel Musto. ‘We’ve been delighted that several of the world’s top sailors, on board some of the most exciting boats – like the Gitana Team – have chosen to wear our kit. In particular the performance of 4DL, our “4-layer durable laminate” reinforcement, was way beyond even our own expectations and the feedback has been superb.’
Main picture: onboard the Imoca 60 Holcim-PRB, which won the first two legs of The Ocean Race. Skipper Kevin Escoffier has sailed tens of thousands of miles in North Sails Performance gear
Nigel Musto wanted to see if he could achieve the Holy Grail of offshore clothing. Was it really possible to create products that would keep you properly dry, as opposed to faintly damp? ‘When we started the North Sails Performance project in 2018 we set out to solve several issues that the marine clothing industry has never been able to resolve. One was the problem of leaking knees and seats. Historically, when creating a robust garment that’s resistant to being torn or damaged by the anti-slip surface on decks, and other snagging points around the boat, it’s been common to put a Cordura patch over the top of the Gore-Tex fabric and then sew that patch into the side seams, but there are several problems with that.
‘The logical route was to laminate something to the outside because with a laminated patch, you don’t need to go to the side seams and you don’t create a wet, damp pocket between the Cordura and the Gore- Tex. The patch material we’ve used doesn’t absorb any water at all, meaning no weight gain in this area no matter how long you’re offshore’.
The biggest challenge was creating a material that would fulfil such a demanding brief, and Nigel Musto says they have achieved it thanks to those clever boffins at the North Technology Group. ‘They had already done great pioneering work in sail design with 3DL and laminated sails, and we were able to draw on that expertise to create the perfect laminate for waterproof clothing.’
Two years of rigorous testing followed, which resulted in some impressive feedback including a ringing endorsement from professional offshore sailor Kévin Escoffier. The Vendée veteran became the early leader of The Ocean Race after skippering Team Holcim-PRB to victory on Leg 1 from Alicante to Cabo Verde. His recent experience cements his already firm belief that North Sails Performance clothing is the best he has worn in his illustrious and adventure-filled career. ‘I tested the same North Sails smock and trousers over 40,000 miles of hard sailing including the Transat Jacque Vabre, Le Defi Azimut, Vendée Atlantique – and the kit is absolutely reliable,’ says the Frenchman. ‘What is just amazing about the North Sails Performance kit is how light it stays even in very wet conditions. The 4DL patches just don’t take in any water at all. It’s great and so comfortable.’
One of Escoffier’s crew for The Ocean Race is British sailor Abby Ehler who spoke to Seahorse soon after the team’s successful Leg 1 victory. Stories abound about the discomfort of sailing on board a latest-generation foiling Imoca. The unpredictability of the bucking bronco ride – as the boats leap from wave to wave only to crash down into a trough without warning – no one is describing Imoca sailing as a pleasant experience. In foiling conditions, wearing body armour, even helmets and mouthguards, has become necessary protection from the random and violent motion of the modern Imoca.
This constant state of readiness takes its mental and physical toll. Offshore gear tends to be bulky and over time, just wearing it can sap a sailor’s energy. Ehler, a veteran of four editions of the Volvo Ocean Race, was pleasantly surprised just how much lighter North Sails Performance feels when you put it on. The difference feels even more pronounced after a few days at sea. ‘What’s an absolute godsend is that it just doesn't feel like you're wearing the kind of heavy offshore gear that we have traditionally worn in the past. Generally what happens is, as you go further and further into a leg, the gear is just getting more and more saturated and therefore it gets heavier and heavier and heavier. This gear is so light at the outset and the 4DL reinforcement doesn’t absorb any water, like the traditional Cordura material, so it stays light – it’s nowhere near as heavy as the gear we’ve worn in the past.’
Other top racing teams who have switched to North Sails Performance gear include the RORC Transatlantic winner I Love Poland (above) and the super maxi Wild Oats XI (below)
With Team Holcim-PRB running a rotation system with the crew, Ehler had yet to find out if she’d be on for the daunting Leg 3. This is a whopping 12,750 nautical miles from Cape Town, non-stop through the Southern Ocean, around Cape Horn and finishing in Itajaí, Brazil. It’s the longest leg in the 50-year history of the round-the-world race, and it’s going to be more than a month at sea aboard some of the most uncomfortable sailing boats ever conceived.
Ehler is steeling herself for the big leg, should she be called upon to join Escoffier’s crew. ‘It’s obviously going to be a cold leg and a long leg. So being able to stay warm, but also to stay dry, is going to be imperative. Whenever you're going on deck to do a sail change it’s going to be wet and cold. You're going to need the thermal layers and the waterproof gear on to protect you. Down below it’s a bit of an unknown how warm it's going to be, but you’re going to need to have a multiple layering system to be able to sleep well. Finding that balance of layering and changes of clothing if you do get wet, those choices are going to be critical.’
Again, the lighter weight and the confidence in the waterproofness of North Sails Performance clothing makes these choices easier. ‘Because you’ve got the lighter material doing the job that much heavier offshore gear would normally do, you’re not feeling like the Michelin Man. There are some really good products in the North range that are not heavy, yet they provide plenty of warmth, and that will really come into its own on Leg 3.’
North Sails Performance Clothing Victory List​
2023 RORC Transatlantic
Monohull Line Honours – I Love Poland
1st IRC Super Zero – I love Poland
2023 The Ocean Race
1st Leg 1 + 2 – Holcim-PRB
2022 Finistère Atlantique – Action Enfance
1st Gitana Team / Maxi Edmond du Rothschild
2022 24H Ultim
2022 Route du Rhum – Destination Guadeloupe
1st Ultim 32/23, Charles Caudrelier – Gitana Team / Maxi Edmond de Rothschild
1st Imoca, Thomas Ruyant – LinkedOut
4th Imoca, Kévin Escoffer – Holcim-PRB
1st Rhum Multi, Loïc Escoffier - Lodigroup
2021 Rolex Fastnet Race
Line Honours: Gitana Team / Maxi Edmond du Rothschild
Nigel Musto says big teams are seeing the benefit of lighter gear when it’s calculated across a crew of 10,15,20 sailors or more. ‘It’s one of the reasons why the Wild Oats XI team has bought a wardrobe from us for this year’s Australian offshore season, including the Rolex Sydney- Hobart of course. North Sails Performance foul weather gear is 30 per cent lighter than traditional offshore kit. Our Offshore Jacket and Trouser combined weigh 1.7kg, which is an average saving of 600g per set. Across a crew of 24 that's an unrated weight saving of close to 15 kilograms - a considerable advantage.’
Konrad Lipski, recent winner of the RORC Transatlantic Race aboard the VO70, I Love Poland, makes this exact point. ‘North Sails Performance foul weather gear is the lightest and most durable kit we have ever sailed in,’ says the 27-year-old navigator. ‘After more than 20,000 nautical miles and three Atlantic crossings, the whole set works perfectly. Thanks to that, we could limit the amount of gear for all crew members on offshore races like RORC Transatlantic Race 2023; every gram less gave a tiny fraction of a knot for over 3,000 nautical miles –all those details matter.’
As Nigel Musto points out: ‘Top teams are ordering North Sails Performance from us and they’re buying it, we’re not just giving it to them. We’re not having to sponsor anyone to convince people to wear it. That’s because it’s not just another variation on the same old offshore kit. What we’ve developed really is a step change in comfort and efficiency on board. Sailors who want to win will always choose the best technology to help them achieve their goals.’
Click here for more information on North Sails Performance »
We invite you to read on and find out for yourself why Seahorse is the most highly-rated source in the world for anyone who is serious about their racing.
huey 2
2,242
syd
Infomercial from Boris and the team of Designers....
and 2000 nmiles to go to Itajai
SECRETS ON HOW MALIZIA RIDES THROUGH THE WAVES​
How does Malizia ride through waves - secrets of our hull shape
by Holly Cova
The shape of our hull and the living space onboard the new Malizia - Seaexplorer are two of the most talked about topics in relation to our boat design. The reasons for these choices and their effectiveness are two hotly debated questions. Now that we have seen how both of them perform and the success of these two elements in the wild Southern Ocean, we wanted to give you more information on how we got here and the thought process behind it. The current conditions in the Pacific Ocean seem to be suiting Malizia and the boat is handling these well during Leg 3 of The Ocean Race.
Daniele Capua from VPLP and Boris Herrmann working on the hull design in Vannes
© Team Malizia
After finishing the Vendée Globe in 2021, skipper Boris Herrmann quickly started to imagine a new boat. The thoughts of how the last Malizia performed were fresh in his mind and although this was a great boat and he did an amazing performance, he was very clear that certain elements needed to be changed. Two weeks after the finish he was already coming to me with the idea that we need to build a new boat for The Ocean Race 2023. Boris had many ideas about how this should look but one of his strongest convictions was around the hull shape and the bow. From his long Southern Ocean legs, he had experienced the boat slowing a lot but also being uncontrollable in the big waves and therefore having to severely reduce speed. He noted that if the hull shape was more curved and rounded at the back (we call this the rocker) and if the bow was more extremely cut away then the boat would be able to ride over the waves rather than becoming stuck each time or nose diving dramatically into the next wave.
With this in mind, Boris reached out to his preferred architects and quickly settled on VPLP to design the new Malizia and Multiplast to build her.
Team Malizia and VPLP working on the hull design.
© Team Malizia
With VPLP by his side the first step was the hull study. This was crucial in creating a boat that could maintain speed in the Southern Ocean. The main focus of the hull study was to optimise the performances in big sea states without compromising the other conditions of sailing encountered during a Vendée Globe. Things that were taken into account include the bow shape, hull rocker and hull beam; these were carefully studied during the design process using dynamic simulation on waves. The main goal was to prevent the hull from slowing down at the bottom of the wave but to maintain high average speeds. The study was then carried out by VPLP and Artemistechnologies who computed the study to try multiple options.
One element that shouldn’t be underestimated here is what race you build a boat for and what conditions. The Vendée Globe is first of all a person and their boat facing unleashed and uncontrollable elements. The wind scenario can change from one Vendée to the next one and it is hard to freeze one concept which would be the ultimate winning concept. Therefore you have to think: Do you build a boat for the last Vendée conditions, an average of Vendée’s that have happened, or do you try to predict the most likely scenarios. Of course, building an all-round strong boat is one answer but then you may not be the fastest.
Vplp drawing the boat designs
© Team Malizia
Quentin Lucet (Naval Architect) from VPLP said, “At VPLP we worked on this idea and found the best technical answer by capturing the feelings and feedback from Boris in order to make sure the skipper can take the best performance from his boat, considering his own human limitations and the feelings he had of the conditions.”
As we saw in 2020, the last Vendée Globe winner was Yannick Bestaven, he won with a 2016 generation boat; whereas the new generation boats which had some better performance in the Atlantic Ocean as there were able to make use of their big foils, did not find the right rhythm in the Southern Ocean. In fact none seemed to find the right settings to achieve good average speed performances in the Indian or Pacific Ocean. Many reported being too fast and then catching up with the waves which then caused them to slow down. They were effectively ploughing into the waves. Which meant they then had to spend time to rebuild the speed to accelerate again. This meant they played with settings such as sail configurations or foil set up or rake in order to actually slow the boats down to stop this happening.
Hull build underway in Multiplast Vannes
© Team Malizia
There were other issues too during the last Vendée that were taken into consideration with the new Malizia. Hull strength and structure were also key elements, with many of the boats less able or confident to push hard in the rough conditions. Sometimes the Vendée is a war of attrition and many of the boats lost foils, sails or had to complete structural repairs during the last race.
These considerations were definitely a key point in the discussions with Boris in the early stage of the new Malizian concept. How can we significantly improve the performances in the Southern Ocean without compromising the boat performances in all the other conditions. As we have seen that Malizia - Seaexplorer with her higher sides, curved hull and scope bow has managed to keep up with some of the newest and fastest boats in the IMOCA fleet, it seems that the decision has paid off. The hull allows the boat to skim much better over the waves, the spoon bow prevents the boat from digging in and then with the correct stacking, ballast and keel kant, the boat is able to lift the nose up without the diving and skim over the big Pacific Ocean swell without slowing down.
Boat flying over the ocean - to see hull shape.
© Team Malizia / Antoine Auriol
The other consideration was the cockpit - although admittedly the initial reason for the larger cockpit was actually due to stability needs. However, as the design progressed the idea of having a cabin where you are completely dry, you can fully stand and control everything internally had a certain appeal. Not just for the obvious reason that it is nice to be comfortable but imagine the wear on your mind and body after only 10 days at sea, then times this by eight! 80 days at sea in very challenging, cold wet conditions. If you can look after the human element controlling the boat then you are highly likely to have a better performance and so the internal cockpit took shape. We have 360 surround windows for visibility and a big aft cabin for sleeping and cooking that remains totally dry. The living area (as we call it) is where the sailors live, spend their waking hours and control the boat from, all the ropes come back here. This is much lighter but also fully enclosed. You have easy access to the outside to change sails through two small doors at the back of the boat.
If you watch the most recent drone videos from Antoine Auriol on board Malizia you can see this type of protection and performance coming to life (click here).
Rebecca Sainson, Boris Herrmann and Loic working on the hull design.
© Team Malizia
Stable and safe in the south - when we designed VPLP analysed many hull shapes going through waves. From the Pacific Ocean on 24th March Boris Herrmann commented:
“WE ARE REALLY SATISFIED THAT IT IS WORKING SO FAR BUT WE ARE HOLDING BACK TO NOT STRESS THE MATERIAL TOO MUCH AND KEEPING THIS DISTANCE OR SLOWLY EXTENDING IT FROM TEAM HOLCIM-PRB BUT WE ALSO WANT TO ENSURE WE PROTECT THE BOAT. IT IS REALLY A BALANCE.”
ET1
153
Germany
The Holy Grail​
The Holy Grail
2023 The Ocean Race
2022 24H Ultim
now, what´s that for. I don´t need that stuff sitting in my armchair
huey 2
2,242
syd
A couple of hours of light and patchy wind...then fill in from the SE then S.....
so who ever gets to the breeze first. without falling into a hole gets around
That said I also doubt that full T rudders will make an appearance. Maybe a bit extra to kick the butt of the boat up.
I think that keeping the max speed under control is an issue. Add a few more knots in big waves like they see now and there is a real risk that turns into broken bones.
Agreed. I can't really think of a way to prevent uncontrollable wave face descents with T foils unless there is a computer constantly adjusting the rudder rake and pitch of a flap. That being said, it's not a safe system to take around the world knowing you're done if it breaks down.
True, the Mini has a 3 m max width they must respect. That being said, using the curvy-arm foils is also a problem now, because you can't neutralize them by putting them back into the hull. Also if you want to depower/slow down, you can raise your foil, and throw a couple hundred kilos of mass up in the air to leeward (not a great idea).
The foil also works as on/off because it's much straighter and can't really have different amounts of lift like a mustache foil can which is the whole point of it.
Then they would have to sway the minds of IMOCA class to make the rule change a thing, good luck with that.
Agreed, Jean le Cam, even if successful, might not change everyone's mind, they'll just start looking for the newer foiler that can beat that boat.
