despacio avenue
399
Alaska
Kevin and Holcims media work is simply too boring or at times not even existing...
I have the same observation. I think Kevin is more focused on winning, and doing so safely with as he repeatedly says with his boat and his crew in one piece, than with PR, though he displays his usual wit in most interviews and routine conversation, albeit they aren't as frequent as Biotherm or Team Malizia, the Party Boat. No puppet shows on Holcim PRB, but Kevin did show how to hotwire IMOCA's.
Herman
2,186
The Netherlands
Holcim-PRB is getting close to CH, around 7 nm and is +/- 22 nm behind TM.
meohmy
15
I'm almost sure they will, the current Verdier hulls were thought with T rudders, and having "different classes within the same class" isn't such a big issue, it is already the case anyway (and different budgets for different sponsors/skippers is the way it works), and a lot of foilers will have the possibility to retrofit with T rudders, like a lot of "daggerboats" retrofitted with foils.
explain your comment in bold..? sounds, smells and tastes like BS
yl75
1,663
France
And you can find interviews where he clearly says his latest Imoca hulls are highly based on this study (finding them will be part of your homework :) , besides showing your mother tits, as is the tradition here for newbies)
And you can find interviews where he clearly says his latest Imoca hulls are highly based on this study (finding them will be your homework :) )
Sam Manuard mentioned that the latest hulls like PRB had a lot from that study in a podcast for TipandShaft, all in French, sorry guys :)
giegs
737
They're definitely showing how to make engaging media content without much support. Every morning I've got updates to check on over coffee - solid engagement. Very fortunate to have a crew that comes across so well on camera.
meohmy
15
sorry, i read your 'current' as 'latest'. I apologise. In a general sense you a right, Linked-Out / Biotherm have lifting rudder in their design DNA.
However, the Volvo Super 60 design brief required it to be a one-design Volvo-specific boat (possibly with lifting rudders etc), but it also had to be a competitive IMOCA (reliable, safe and up near the front, but not necessarily winning). This was directed from Volvo so teams could do both races and widen the appeal, create a market for the boats etc etc. So I'm not even sure you can say Linked-out is optimised for lifting rudders.. its results would say it was well optimised without them..
PRB and 11th Hour were both done well after the Volvo Super 60 was scrapped. This is even true for Apivia, a custom shape away from the VS60.
None of the boats that were actually built were ever optimized for lifting rudders. That would be a pretty dumb move to build a boat around a feature you know you can't have.
What we meant is they did the study and used it as a starting point before adapting it to a configuration without lifting rudders. The results of that study undeniably influenced the designs and they took it as a starting point for some of the boats but of course they totally reworked it, in part to account for non-lifting rudders.
For instance, I'm quite sure today's boats have a lot more rocker and the bows are wider/flatter than what was studied for the "Super 60".
Biotherm tried to cut it too close to the wind hole to shave off some miles... and got cut off. Now basically stopped (0.5 knots) while 11th hour are sailing over the top of them.
Wind should be back to them within the next 12 hours but 11th Hour will be gone by then.
dg_sailingfan
1,090
Augsburg
Going to take Hours for Biotherm to get going again. They might be 50-100 Miles behind 11th Hour when they reach Cape Horn tomorrow UTC.
Of Course Malizia & Holcim will likely be 400+ Miles ahead of 11th Hour.
They both have a nice Weather System to take them north and they might hang onto it until around Buenos Aires.
