JonRowe
1,217
Offshore.
Seems to be a more general problem than just the wind instruments and they mention losing "the computer" whatever that encompases. They must have some electronics online because you don't sail an IMOCA in a blackout.
In the past there have been poles with a wand at the top put up from the windward side like Alex Thomson did in the Vendée 2020 so that's an "easy" system to implement.
They usually have two wands at the mast head and at least one spare wand they can then mount as you describe, as well as a full backup autopilot, but if they are referring to the processor it may be they don't have a spare processor, or they are still debugging whats broken with the processor.
In the video you can hear the autopilot and see B&G displays showing boat speed, so they're not in a black out, just no wind data at the time they were reporting.
noaano
502
Do they use conventional spinny thingies or ultrasonic ones?
Ultrasonics are very reliable, never had one fail. Few times its been filled with snow / slush though, wish there was a heating element like in the commercial weather station ones from Vaisala :)
I would guess they have a backup / spare. Why would you not? Even many cruising boats have two permanently installed...
Random question: there is a carbon V-shaped object suspended from the cockpit ceiling of Malizia. Can anyone tell me what the purpose of this thing is? I'm guessing it is some kind of antenna. Definitely not a handhold, nobody ever seems to grab it. You can see it here, looker's left of Nico's head.
1600x0
minca3
800
1600x0
tiller; I think the axle goes through the roof and a tiller can be mounted outside on top the roof.
glexpress
152
Hill Valley
1600x0
That is the tiller. I saw a video on one of the first legs where they explain it. I cannot locate the video now..
JonRowe
1,217
Offshore.
As far as I know spinny things are still more accurate and tend to be what the top end systems use, certainly haven't noticed any not using them but thats just my mk1 eyeball anncedotal evidence.
Pass, everything is a trade off for weight / cost / reliability, often the backup system isn't as fully featured as the main system or is a different brand or independent, so it could be a series of failures, configuration or lack of parts, or who knows, I guess we may find out or we may not 😂
noaano
502
On the weather stations, airports and like, they've chanced to ultrasonics mostly, same I have noticed in tunnel ventilation monitoring etc.
I would think modern ultrasonics to be more accurate especially with very low flow speeds and react faster, and they can sense the 3D direction of the flow, but the accurate models need a longer baseline and are thus quite large. Maybe that is the reason.
this one claims sub 50g:
ct800
40
So TM has lost/ripped the MH0 after Cape Town, but they do have another masthead sail as seen on pics/videos. Is that something of a J0?
I'd assume the lack of the big masthead sail is hurting them in comparison to HPRB in the sub-15 knot wind range, hence the bleeding of miles.
Boris being optimistic of a strong downwind finish after some upwind conditions on Fri-Sat in the latest video.
JonRowe
1,217
Offshore.
I'm sure they're getting better and are most likely the future, I expect at the moment its the decades of experience we have with building and calibrating the mechanical ones, a stationary datapoint is a lot easier than one moving around in airflow too
Tiller it is! Thanks for all the answers. I had even watched that boat tour video but apparently missed the tiller explanation.
It's one of so MANY design choices that make the boat so much more sailor-friendly. You can reach that tiller from almost the entire cabin, especially up near the pedestal and lines and to the sides by the seats for the AP controls with the good canopies, instead of a stick back aft with a tennis ball on it. Boris really thought through how he wanted her laid out, especially for single-handed sailing. I think all of that must really make a difference in human performance under really trying conditions.
