dg_sailingfan
1,086
Augsburg
Really wishing these updates came in more frequently. Looks like Holcim and Malizia will be neck and neck for a bit.
It is THAT CLOSE folks o_O
littlechay
657
Nelson
I don't see this as a problem.
These boats have 10-100Hz IMUs already.
The ultrasonic sensors are not as accurate typically around 1 degree and a bit slower to react due to sampling period and such. They often have built in IMU and heading sensor so can provide a direct output in true wind (good on rotating masts). Yes they have heaters for cold weather but they don't seem to be very effective, a good hail shower can clog them up they they take time to defrost.
So analogue is faster to react to changes in wind velocity, and more accurate in terms of direction, but requires additional processing for true and to cancel out mast head movement. Ultrasonic is more robust and the built in electronics can give direct true wind output.
oioi
134
I don't understand the flat uncushioned seats. I would think they'd be pretty uncomfortable for long periods and could do a better job of holding the helmsman in place in seas. That's a lot of energy just to stay in position.
I have these in my car
Amazingly comfy. I've done cross Europe runs in it, spending 12 hours in them and they are soo comfy. Great thing is, you drill a hole in the bottom of them, the water goes straight out and they stay dry ( my car doesn't have roof / windscreen). A foam / cushioned one will fill with water and be a nightmare. I'd put them in a race boat! I would also fit harnesses, so would limit the crashes, take some of tension out of the muscles
Grog
Anarchist's Anarchist
1,440
1,059
Germany
once again fantastic drone footage;
3 raised headsails tell the story of changeable conditions.
I have to say, she does seem to be dialed in and performing rather nicely.
I also have to admit, I did not expect to see a foiled IMOCA to ride that smoothly in racing conditions.
Well done, TM, keep going!
noaano
502
This is due to the short baseline in the marine units though.
Longer baseline units like they use in weather stations etc - like Vaisala ones - are accurate to 0.1 deg or even more precision. And in 3D.
But they're quite large, as the baseline is multiples of decimeter.
That's about what I was thinking, though 4 different sized crew members. Even just closed cell pieces like backpacking pads would be something. Belts are a good idea, a concussion alone on VG would be a real problem, eg. Idk, maybe the flat seats are to keep you from falling asleep. 😊
dg_sailingfan
1,086
Augsburg
@TheDragon
Boris Hermann said expects some upwind conditions Fri & Sat, then downwind on Sunday.
Do we know the performance of the two Boats upwind?
I remember Holcim & 11th Hour in their Tacking Duel down the Spanish Coast towards Gibraltar in Leg 1 when Holcim came out on top.
If that is any anything I expect a ferocious tacking duel between Malizia & Holcim tomorrow and Saturday.
erdb
619
@TheDragon
They're not going to do much upwind sailing. Only the next few hours in light winds. That should favor Holcim, but then there's a lot of downwind in heavy conditions. TM have been excellent in those, but they'll have to keep the boats in one piece.
dg_sailingfan
1,086
Augsburg
Kevin Escoffier is not going to take a risk. Malizia for now ain't a serious threat for the Overall win. Kevin will just be content beating 11th Hour Racing Team.
Malizia will be at a disadvantage in the upcoming Leg 4 I think. That Leg will be more about Trade Wind Sailing + Tactical Skills.
Swanno
Looking at the next few days of wind, the down wind conditions the remainder of the race are starting down where 11th hour are and will roll up the coast all the way to the finish, overtaking the fleet sailing through this light windward stuff.
TM are doing everything in the playbook to get between HPRB and the finish though the last 24/36 hours of the race looks to be in a building southery.
This is going to be a thrilling finish of a a 12000 leg!
Go TM!
Must admit I am concerned about the condition of Rosie - it seems that the joviality on the boat had substantially lowered, though i guess they are having to match race for 1000 miles.
TM are doing everything in the playbook to get between Biotherm and the finish though the last 24/36 hours of the race looks to be in a building southery.
Go TM!
They're down 25% of their crew for days, they've got to be REALLY tired.
Rainbow Spirit
134
Sydney, Aus
Go TM!
I guess you mean Holcim PRB and not Biotherm
