I want to connect a Sennheiser Bluetooth Audio Transmitter to a Yamaha A-S2100 Integrated Amplifier. The transmitter accepts input through a 3.5mm plug. The amp has a headphone jack that could be adapted to receive a 3.5 mm plug. Sennheiser anticipates the transmitter will be connected in this way.
My need would be met better by connecting the transmitter to the twin speaker outputs on the amp. In this way I could toggle between Speakers 1 and 2, with 2 going to the transmitter. The amp shuts off the signal to the speakers automatically when a plug is in the phone jack. The automatic shut-off requires that I unplug from the phone jack on the amp every time the Bluetooth transmitter is not in use. I cannot simply leave a plug in the phone jack and switch the transmitter off. I can avoid wear on the plug and amp by switching from Speaker 1 (ambient sound) to Speaker 2 (Bluetooth transmitted to headphones).
I need to connect the dual 6.35 mm outputs labeled "Speaker 2" on the amp to the analog 3.5 mm single input accepted by the Sennheiser. Connecting the devices this way seems idiosyncratic; every cable I've found works in the opposite direction. The signal from an I Phone or like device enters the 3.5 mm end and the cable splits the signal in two for output to a speaker. I want the amplified signal to run from Speaker 2 (left and right outputs) to a single device, the Sennheiser Transmitter.
My need cannot be met simply by running the signal in the direction that is opposite to the design of the cable. The splitter function (one signal to two) does not work in reverse.
Any thoughts?
Any thoughts?
