justsomeguy!
Well, you are wrong.I’m fine with the mixed wood species
Padauk, red oak, poplar (hidden in back), cherry, maple and walnut? Painted?Mixing wood species is fine, providing they match. And if they don't, there's paint.
There's plenty of room behind there.you've covered it up so your obviously not concerned about it's effectiveness.
It's not an act!Padauk, red oak, poplar (hidden in back), cherry, maple and walnut? Painted?
Too much! Oiled.
Yer actin' silly.
I like it.
An example of different people have different priorities?And this kinda proves my original point; only the maker sees the faults.
Except for the off-center return. Totally missed that one.![]()
And some silly ones, too.There's a particular cohort of crazy here.
I did fix that part.
There's plenty of room to get a broom behind them, and to reach in for connections.having speakers against the walls? shame.. they need room to breath..
With crowned tires your blade should track in the center of the tire. with flat tires your blade should track towards the front, with the saw teeth hanging over the edge.I bought a Jet 18 in bandsaw about 25 years ago. I later replaced the factory tires with urethane tires. Both the factory and replacements were crowned.
So when I had to replace the urethane tires recently I just ordered new ones, believing they will be crowned. Cut I thought the crown was a must.
Well, the new ones arrived flat. After doing some research I find crowned tires aren't a must. Learned something new.
In other words, don't have the teeth on the tire? That would put the teeth over the steel rim.With crowned tires your blade should track in the center of the tire. with flat tires your blade should track towards the front, with the saw teeth hanging over the edge.
On some saws there is a tilt adjustment for the top wheel. Get the tilt right and the blade tracks in the center of the tires. All the big metal cutting bandsaws I used had that feature.In other words, don't have the teeth on the tire? That would put the teeth over the steel rim.
I haven't put the new ones on yet so I don't know if the flat tire will clear the rim in height.
Are you out of the same paint you had used on the wall? Slather some more on those red marks.Have to paint the wall again.
You'll probably be the only one that notices any difference.
Oh, and then return that POS level.
And be sure to use good thick paint.Alternatively, paint the level the same color of whatever you are going to use it on, before every job.
It's a lot of work, but we are seeking perfect, oui?
they found themWasn’t someone around here looking for some of these a while back?
Antique Iron Window Weights - antiques - by owner - collectibles sale
12 inches long, approx 4 pounds each, 4 available, $5.00 each.lansing.craigslist.org
Thank goodness, we won’t have to discuss them then.they found them
It should. The idea of the crowned tire is that it doesn't affect the set of the teeth on one side. Same with the flat tire and having the teeth hang in front of the wheel.In other words, don't have the teeth on the tire? That would put the teeth over the steel rim.
