shaggybaxter
They’re all mad as cut snakes. They spend most of the time stacked on the rail as near to the bow as possible screaming more more more ....Are you trying to kill 'em all in one go?!!?
Is the hatch not central?Are you trying to kill 'em all in one go?!!?
Open the pic in preview, rotate it and save it.Me too, really! Well, here you can see it blocking the entire back half of the cockpit:
(IPad turned it sideways of course) it’s the black thing in front of the tiller, spanning the whole beam- end sheeting
Different strokes, if its set and forget then why not; do what you like but there is no way youll be competitive in a short race with that setup.There's one well-known ocean racer who's used a twin mainsheet system....
Jean-Luc Van Den Heed.... who sailed his MatMut to a 'win' in the last Golden Globe Race. That was, for those who've forgotten already, a single-handed RTW race in often serious weather and seas. There were other competitors who had similar setups - you'll need to ask yon Don Macintyre, a fellow 'Strine.
How much strength does that traveller add to the cockpit? Or the aft part of the hull? Will you need to add some deck/hull reinforcement if you don’t have the track there? Thinking about bending forces from backstay, runners etc.So after much messing about and thinking and pricing replacement track and car etc to replace current setup. I’ve decided im doing the install and setup for the Double blocked padeyed setup. So that when the existing traveller car and rail fail i’ll be ready to have the walkthrough cockpit setup. Thanks again for all the interesting input in this thread.
See you out there.
Reminds me of an unfortunate heavy air gybe accident on a Farr 40 about 10 years ago.This would be a nightmare in a heavy air gybe. Two set of ropes that act as deck sweepers and grab every cleat and winch on the way over.
The key difference being, regardless of point of sail both blocked mainsheets in the “A” remain tight. Therefore there is no slack in the mainsheets and it also prevents full beam accidental crash jibs. Sorry to hear about your buddy.Reminds me of an unfortunate heavy air gybe accident on a Farr 40 about 10 years ago.
One of my buddies lost his balance and happened to step into the middle of the mainsheet rats-nest that very briefly gathered on the deck mid-gybe. As the mainsheet tensioned on the new gybe, one of the coils flew up his leg, constricted just above his knee, and promptly hoisted him into the air, upside down, hanging by the knee, with the full power of the mainsail tightening the mainsheet tourniquet around his leg.
We promptly gybed back, literally dropping him on his head.
I think he's still physically and emotionally scarred from that incident.
If that happened singlehanded the only solution would be to start cutting - hopefully there is a knife very close by!
Indeed a good point. In this particular boat the centre section of the track mount is seperate so it isnt a Key reinforcement point. But indeed removal of it will be rebraced under(as iam wary of change).The hiking bars and deck mounted track beam sections will be used as the new setups mounting points.How much strength does that traveller add to the cockpit? Or the aft part of the hull? Will you need to add some deck/hull reinforcement if you don’t have the track there? Thinking about bending forces from backstay, runners etc.
Was the traveller working at all against any longitudinal cockpit wall athwartship buckling?The key difference being, regardless of point of sail both blocked mainsheets in the “A” remain tight. Therefore there is no slack in the mainsheets and it also prevents full beam accidental crash jibs. Sorry to hear about your buddy.
That said, i have plans to reinforce under the cockpit area to aid the A move/extension of the fuel carry capacity under it also. Right now the entire cockpit sole area is supported by the full length horizontal hull and deck reinforcement, and 2aluminium tube legs under the companionway entrance. Strong but light for offshore racing.
The internal structure is braced as is, tho i may beef that up a bit once removal of the track. But according to the drawings it isnt a structural necessity and it isnt installed heavily or triangulated.Was the traveller working at all against any longitudinal cockpit wall athwartship buckling?
fwiw, I had a system like the inverted v, and depending on how you do it, it can be a deep rope floor. Messed around between 8:1 to 12:1. Loved the feel of 12:1, but that should have been a fine- the bitter ends were tied off at the inside on each side, with a continuous line going between. Required some though to use, but it didn’t run out of line like separate lines. I would recommend a 2:1 or 4:1 for the real light stuff that doesn’t interact with the rest. Use the rest as a cascade, but That winds up crossing itself a lot., as well as a lot of cleats. If you’re going to do that make sure you have different colors that don’t mystify when the going gets sporty. I thought a triple cascade would be cool, but I never got around to that. Fiddles worked the best- the normal 3 blocks in a line never ran very smoothly.
Thanks- she’s a sweety. I’m not sure 4:1 will be enough- you can arrange it so it becomes an 8:1, or add a 2:1 cascade to that for heavy weather 16:1. We have a ~500%+ sq ft main.The internal structure is braced as is, tho i may beef that up a bit once removal of the track. But according to the drawings it isnt a structural necessity and it isnt installed heavily or triangulated.
The setup i intend is the same as in the above video clips. Which is essentially two seperate Double blocked and cam cleated (4:1i think) one port to boom and one starboard to boom.
Your boat sure is a good looking sled.
One thing I do that gets rid of rope in the cockpit from the main sheet system is what I guess you could call a pennant that goes from the traveller cars connector to the bottom blocks, about 2’- 3’, which on a 10:1 can save quit a bit of line. The drawback is that I use a cam cleat on the bottom block, and getting the thing cleated can be awkward, because it’s it’s pretty high. Uncleating is easy though, sometimes too easy :lol: , but with the full width traveller I don’t need to let the boom out much. Or vice versa. One of the blessings of 22.5 degree swept spreaders. 6’ of thick spectra (for the pennant) doesn’t cost much, and the last one I just replaced was 8 years old or so, no sheathing, held in place by a square knot, of all things. I whipped the ends to the main loop. The working strength of that spectra was 150% of the weight of the boat!Reminds me of an unfortunate heavy air gybe accident on a Farr 40 about 10 years ago.
That's basically a dinghy system. It doesn't really substitute for a traveler, it's a way of centering the boom without massively tightening the leech if you don't want to.
