TUBBY
ALL rating systems should have a provision to consider the difference in the weight of the owners wallet between the beginning and end of the season!
The very thing happened to my boat and a Farr 30, in 2018, race was scored TODToT can can provide unbalanced results. For example, if the fleet starts in light air and one smart fast boat finishes in such conditions, then a front blows through or a huge pressure difference ensues, the rest of the fleet benefits from a horsepower increase. The guy (opps, I mean the X) who won the start, caught every light air shift and crossed the line 1st get's penalized on ToT. Pure PHRF works best. ORCi, IRC, IMS, IOR ....the Queen Rule of PHRF has and will watch them all fall by the wayside at the industries, owners and club committee''s great expense. Hey wait, what will the designers do with no new rules?
How does that differ from time on distance? The same thing happens when the wind fills in from behind and brings the fleet down you.
There is not much difference between ToT and ToD as far as it effecting the results.The word is losing, not loosing.
My club has been racing under PHRF/TOD sinc I started racing in the early 80s. Every year when we adopt the racing calendar and rules for the season the question is always asked whether we want to go to another rating system. At one time we had an IOR section. As those guys changed boats or retired the remainder came to race under PHRF because that’s where the action was. We had a J/24 one design start for a few years until, again, those skippers stopped racing or moved to bigger boats. There was, briefly enough T-10s for a one design start but they too went extinct. We have an active Star fleet that follows their own desires and about 4 or 5 S2 7.9s that race one design. The few boats left race PHRF and there does not seem to be any measurable level of discontent.
Seems unnecessary somehow.If they allow me to be PRO for the Fall PHRF series, I am introducing a whole new twist. I will take every boat's PHRF rating and put them into a hat. Then on Thursday lunchtime, I will read out the boat names in alphabetical order and pull out a rating from that hat......and that will be your rating for the evening. It will be a whole lot of fun and should discourage people spending money trying to exploit loopholes.
"USSS is not interested". TRUE! because they follow the users... they only want the role of facilitator... not leader.... So... the fuckery will continue because the users want it that way. sailors have a dna based aversion to big sailing telling them what to do!PHRF should be an international rule, but seeing as how most countries use mathematically driven handicap systems, no one needs or wants PHRF. So at a minimum PHRF should be national, not regional. Even then I see room for corruption due to the lack of meaningful measurements and the heavy customization of production and former one-design boats. It also has no reason to exist, USS is uninterested and without a national authority there is no foundation for this idea.
ToT seems to have more issues than ToD but ToD is not perfect either. No one wants to score a race the way a high level IMS event might be scored. I swear the old D-PN/NA-PN Portsmouth rule might be the best rule to ever rate boats. It provides different ratings for different wind conditions which is better at capturing boats with a wide range of potential performance points. You only need to take a few wind readings as the race progresses and then average them and use a single rating for the final scoring. Imperfect but very good and better than everything other than IMS, but importantly without the pain of IMS per leg ratings.
Tcatman, you are so right. US Sailing is a complete and total failure. After having been part of several previous Paralympic Cycles and dealing with USS, I figured out, It is a pile of shit. Then representing my local area and sitting on the So Cal PHRF Regional board. I realized no one really wants to fix anything. People get on the board and reside in various seats for a dozen years just so the can say "Bla Bla Bla, I was there." and pad their resumes. I could name one in particular, but I would be called out by the LGTBQUAXYZ org.PHRF should be an international rule, but seeing as how most countries use mathematically driven handicap systems, no one needs or wants PHRF. So at a minimum PHRF should be national, not regional.
Wind speed ratings allows you to define a performance curve with three points rather then a straight line... Makes sense to me but it seems to fluster a lot of clubs.
Portsmouth has calculations as well and an expectation of rating them against similar boats. What you just described is how PHRF works."USSS is not interested". TRUE! because they follow the users... they only want the role of facilitator... not leader.... So... the fuckery will continue because the users want it that way. sailors have a dna based aversion to big sailing telling them what to do!
a national phrf system made sense 30 years ago to me... and yet fuckery will continue to the end of time..
Portsmouth is the worst rule to use for big boats... Portsmouth requires a fleet of one one design class defined as the yardstick and in the US system only the first boat of the fleet data is used... the class being handicapped also requires a fleet of one design boats and again only the first place boat data is used.. You need fleets of boats to make the statistics work. So it would rarely apply to any handicap race in the states. and then of course you have too many one offs and modifications to manage. So garbage in and garbage out for ratings.
Same standard... is it good enough? How transparent or subject to fuckery is it. Can most OA's run and score the race fairly?The owners sailing around under ORCi are not so happy these days BTW.
I agree with what you say regarding PHRF. But not sure about ORCi. What is the issue? FYI I do sail under ORCi and would rather do that than sail under PHRF.A National PHRF Rating Committee should be in charge of assigning ratings to all identical boats. This pulls the regional politics out of it. I have been in the smoke filled rooms in the distant past and watched the political decisions made to eviscerate a boats value with one tip of the ash off a cigar. For example a stock production boat should rate the same in all regions. A Tartan 10 is a Tartan 10, if you modify it, you take a hit. If it is stock, you are expected to have a perfect bottom, new sails and rigging. If you don't, then you should expect to get your Arse kicked.
With no ability to check the facts at the time, the rating appeal system was based on flawed and politically charged misinformation. These days, we have the technology to prove and expose the BS at our fingertips.
When I was a local PHRF Rep, I could never buy a drink. I also remember, if you bought sails from another Rep, you were protected, protected.....please ignore that new mainsail, and can we give him a 3 second reduction, it was part of the deal.....
Back in the ‘90s our club had a discussion of changing from TOD to TOT. Lots of opinions, few facts. So a couple of guys and I arbitrarily took 5 years of TOD results and converted them to TOT. Some shuffling in the results at mid-pack and below, but the top boats remained the top boats. As you said, when you suck you suckThere is not much difference between ToT and ToD as far as it effecting the results.
I ran a Wed night series for a couple of years and my hack friend with the scratch boat would complain to me that the numerator/denominator was wrong and if we used what he recommended he would have won. So each week I would have the scorer rerun the results for me with his formula and all that happened is the times got closer the results stayed the same.
I would even go 1 better and have the scorer run them time on time for me so I could tell him he still sucked.
In one race out of 10 did the results change and move him from 4th to 3rd.
When you suck you suck
There is a National PHRF Committee. They publish a national ratings book. It would be considered sacrilege if the PHRF National Committee tried to impose national ratings on the regional RSAs . There would be an uproar likely led by PHRF anarchists screaming that their liberty has been infringed by the bureaucrats from Bristol. The whole purpose of PHRF is that it is devolved and local. "PHRF handicaps are assigned by committees associated with specific fleets. Handicaps are assigned to a given class considering predominant local conditions and experience based on observed performance " PHRF is "historically used for USA casual fleet racing"A National PHRF Rating Committee should be in charge of assigning ratings to all identical boats. This pulls the regional politics out of it.
Care to guess how many PHRF racers know this principle?..... even better... how many agree with it?The role of PHRF, not unlike a golf handicap, is to level the playing field. If you spend a ton of money to improve your boat's performance within the local PHRF fleet, you should expect your rating to start falling, until the playing field is level with Joe's 4 k shitbox again.
The Boston Yacht Club PHRF racing lived by that principle. It was great when I lived there. If you finished in the top 3 you got time withdrawn from your handicap, automatically, no questions asked.Care to guess how many PHRF racers know this principle?..... even better... how many agree with it?
It's a bit like US Portsmouth and RYA Portsmouth.
It doesn't.The RYA portmouth tosses the top finishers of the OD class
I score our YC race races with Sailwave and the BCE is a great tool. When boats are seconds apart on corrected times, people feel great. But in a fleet where they are minutes apart, I scratch my head and wonder why. It is usually, not enough crew, bad spin sets, gybes, tacks, starts or over standing the laylines, bad driving and going to the wrong side matter too. That was all the things that matter in sailboat racing in a nutshell except for boat prep.I think the best way to manage the smoke is to explain handicap race results with any rating system is to express the delta's between the first place boat and your finish as the back calculated elapsed time...(Sailwave) take the rating used that day and compute the actual seconds you lost by....and then ask... OK... you lost by 30 seconds and you were 10 sec's off on the start... or the fubar'd tack cost you 10 additional seconds. Similarly, when you look at a one design race score sheet... Finish positions are misleading. publish the delta behind in seconds to really get a sense of performance, mistakes and serendipity that give you that result..
