There are a bunch of threads about annoying Tohatsu dinghy engines, and dealing with them, and also some threads about converting them from 4 to 6 hp. I just fixed the bad behavior of mine by converting it from 4 to 6, so I thought I would write a post that someone else might find in the future when they were looking.
Short version: do this. Its easy, the engine runs like new, and the increased power is good.
Longer version:
We had a six year old Tohatsu 4hp on a North Atlantic Inflatables aluminum RIB. 10 feet long. Weighs 125 pounds. We chose aluminum because I run it up on rocky Maine shorelines several times a day to walk the dog. With the 4hp it was displacement only with two, and would try to plane with one person, if that person went all the forward, but mostly made a lot of noise without much go. With the engine converted to 6hp, it will plane with two (360 pounds together) and run at about 8 knots. With just me it maintains 11 knots.
The conversion consisted of the carb only. I haven't re-propped it because I don't really understand props yet. The conversion took five minutes, after I fished the engine back out of the water and dealt with drying it out. Thank you imaginary voice that reminded me to tie a line to it. The conversion requires the removal of two screws, and a pair of pliers to deal with the fuel line keepers.
The carb was delivered overnight by Defender. Cost with a fuel filter and new carb gaskets was $105. The engine starts first pull again of course.
If you're reading this because you were searching for information on this conversion and wondering whether to do it: yes. You should do it. It does seem to drink more than half again the fuel for only half again the power. Remote tank will go in next.
YMMV. Do not taunt happy fun ball. Past gains do not guarantee future performance. Do not taunt happy fun ball, etc.
Longer version:
