Transpac 2017
~HHN92~
58
....and who is their tactician? Rimas? They keep heading south towards Alaska.
I heard something that they may have a limited sail inventory, the boat should be faster than that, or they had an issue early and pressed-on anyway. I know a guy on the boat and will have to check with him when he gets back.
hbsurfer
2
can you post a link to the story?
At 0015 Sunday July 9th we struck an unseen submerged object at a speed of 18-20 knots. We believe that it first struck the keel, then ran along the portside, until it struck the port rudder. The ensuing impact completely snapped the rudder just below the upper bearing. The rest of the stock and the rudder were now free to swing about, destroying the lower bearing and threatening to tear a hole in the boat. Since we were on starboard tack, copious amounts of water were pouring into the boat.
The first order of business was to slow the boat down to try and keep the free swinging rudder from doing more damage. The kite and the staysail were dropped and with the reduction in speed we were able to keep up with the ingress of water with our pumps.
With the water somewhat under control, we needed to come up with plan. We knew if we gybed, we could heel the boat enough that the damaged bearing would be well out of the water, but the boat would also pick up speed, which in turn could cause the rudder to rip a hole in the boat that we would have very little chance of patching. It was determined that we needed to get the rudder out of the boat quickly and get the hole covered.
Luckily for us, we have a very experienced crew who have all been with the boat since its christening, plus we have onboard  multiple Volvo veterans, Chris Nicholson, Justin Ferris, Bouwe Bekking, Will Oaxley, and our own ace craftsman and Magyver, Jeff Messano onboard who came up with a plan.
Jeff quickly went to work rounding up parts to cover the hole, while the others came up with a way to secure the patch. But first we had to get the rudder out of the boat, which meant keeping the boat as slow as possible, which in turn meant the boat was flat and water would flood the compartment. when all preparations were complete, everyone except for Jeff left the compartment. The plan was to push the broken rudder out of the of the boat, stuff a sleeping bag in the hole to stop the water until we could  pick up speed, heel the boat, and make our repairs.
Come on retirement!
Retirement is everything it's made out to be...weekends are seven days long...all the time...even in Hawaiian time!
still reminiscing   about the Islands—Trade winds,   old stories, old dreams  —Captain Gigi  •...png
Shu
96
Since they were without daggerboards, I wonder how long Comanche sailed with the keel centered.  Certainly to Catalina; but how far aft do they need the wind to be before they can cant? Fascinating.
Shu
96
Medusa must be having issues.  At one point they were sailing nearly due north.  Now they are back on course but at limping speed, 4 kts.  I pray all are ok.
Shu
96
must be light, the CAL 40 is only doing 3 knots .
Ouch. Medusa is back over 7 kts now, but still woefully slow, given the rest of the fleet.  It looks like it's going to get light for most of the fleet in the next 24 hours.  Rio and Invisible Hand, maybe Bad Pak might escape, but the rest look doomed.
J/120
Just read this thread. Why the hell are people still comparing monos and multis? Can an F1 car outpace a NASCAR car? Of course. Is NASCAR racing more car on car and F1 is not. Of course.
Two different boats, two different cars.
So... Rio lost a rudder, had to make "at sea repairs", limped in a day and a half behind Comanche, but still beat her!
Kind of takes away some of Comanche's thunder or is the rating system that skewed?
Go Merlin and Hobie 33!
J/120
Comanche was not built to rate.
