Vespucci
I’m looking for thoughts and suggestions that might explain a pronounced port/starboard performance difference in my boat. In medium/heavy air the performance seems fairly symmetric, no obvious bias on one side or the other. In very light winds, though, the boat seems to go faster on starboard tack than port.
a few notes:
1. The boat hull and appendages were laser scanned a year or so ago in order to get an ORC rating (that’s another story). From analyzing the 3-d data it is hard to find any discrepancy in the hull / keel shape from either side. Certainly if there is any it’s less than 1cm.
2. The speed sensor is on the starboard side and clearly ends differently depending on the tack we are on, BUT, GPS speed doesn’t lie, we are consistently almost a knot slower, and pointing lower on port than starboard.
3. to the best I can tell, the rig is symmetric and the rig tensions about the same on either side.
4. having local ‘good sailors’ on board always results in their comment about the feel of the boat being different, with no mention or ‘leading’ from me.
so any thoughts, or suggestions as to what I might do to figure this out?
this is a very long shot, but I begin to suspect that the battens on my jib are the culprit. The boat has a 100% non overlapping jib on a furler, and so has 4 vertical battens on the leach, each almost 5’ long. These battens protrude significantly on one side of the sail, and not at all on the other. See the photos below which show either side of the batten to get an idea. I’m starting to think these battens are really disrupting air flow when they are in the “underside” of the sail - which would correspond to the port tack, but hardly disrupt flow when they are on the upper side of the foil Seems a long shot as an explanation.
thoughts or suggestions?
a few notes:
